Torque on Charges in an Electric Field
The problem involves calculating the maximum torque on a dipole formed by two charged spheres in a uniform electric field. The formula used is t = qEL, where q is the charge, E is the electric field strength, and L is the distance between the charges. The calculated torque is 3.15 x 10^-4 Nm, which is the correct unit for torque, not Joules. The discussion clarifies that torque is indeed measured in Newton-meters (Nm), confirming the solution's correctness. Understanding the distinction between torque and energy units is crucial for solving similar problems.
Mitchtwitchita
Two small plastic spheres, one charged to 17 nC and the other to -17 nC, are connected by a 25-mm long insulating rod. Suppose this dipole is placed in a uniform electric field with strength 7.4 x 10^5 N/C. What is the maximum possible torque on the dipole?
t = qEL
t = qEL
=(17 x 10^-9 C)(7.4 x 10^5 N/C)(2.5 x 10^-2 m)
=3.15 x 10 ^-4 J
This can't be right. Is torque measured in Joules? Can somebody please help me out with this problem?
Your unit is Nm, which is right for torque, not the equivalent J for energy.
How about the solution?
Looks correct to me.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
