MHB Torres' question at Yahoo Answers regarding minimizing the cost of a box
  • Thread starter Thread starter MarkFL
    Box
To minimize the cost of a box with a square base and a volume of 6000 in³, the cost function C is derived based on the costs of materials for the top, bottom, and sides. By substituting the height in terms of the side length into the cost function, the critical point is found by differentiating C with respect to the side length and setting the derivative to zero. This leads to the critical side length x being calculated as (3/5 * 6000)^(1/3) inches, and the corresponding height h is determined to be (5/3 * 2 * 30^(1/3)) inches. The analysis confirms that this critical value minimizes the cost of the box.
MarkFL
MHB
Here is the question:
CALCULUS question HELP?
I want to make a large box with a square base that has a volume of 6000in^3. The material for the top and bottom costs 5 cents per square inch and the side material costs 3 cents per sq in. Make a function C that represents the cost of the box in terms of the side length of the bottom of the box. Find the one critical number for C and then give the dimensions of the cheapest box.
I have a final for calculus so I would like to know the steps on how to find the answer. If you could do that it would really help. Thank you in advance.
I have posted a link there to this thread so the OP can view my work.
edit: Before I could post my solution the OP deleted the question.
Mathematics news on Phys.org
Hello torres,
If we let $x$ be the side length of the bottom of the box and $h$ be the height of the box, then the constant volume V of the box is:
$$V=hx^2$$
This is our constraint.
If we then let $c_1$ be the cost per unit area of the top/bottom and $c_2$ be the cost per unit area of the sides, then our total cost function $C$ is:
$$C(h,x)=2c_1x^2+4c_2hx$$
This is our objective function.
Now, if we solve the constraint for $h$, we obtain:
$$h=\frac{V}{x^2}$$
Substituting for $h$ into the objective function, we obtain:
$$C(x)=2c_1x^2+4c_2Vx^{-1}$$
Now, to find the critical value(s), we should differentiate with respect to $x$ and equate the result to zero:
$$C'(x)=4c_1x-4c_2Vx^{-2}=\frac{4\left(c_1x^3-c_2V \right)}{x^2}=0$$
This implies:
$$c_1x^3-c_2V=0\implies x=\left(\frac{c_2}{c_1}V \right)^{\frac{1}{3}}$$
We can see that for values of $x$ less than this critical value the first derivative is negative and for values larger than this critical value the first derivative is positive, therefore by the first derivative test we may conclude that this critical value is at a relative minimum.
Thus the height of the box at this critical value is:
$$h=\frac{V}{\left(\frac{c_2}{c_1}V \right)^{\frac{2}{3}}}=\left(\left(\frac{c_1}{c_2} \right)^2V \right)^{\frac{1}{3}}=\frac{c_1}{c_2}x$$
Now, plugging in the given data:
$$V=6000\text{ in}^3,\,c_1=5\frac{\text{¢}}{\text{in}^2},\, c_2=3\frac{\text{¢}}{\text{in}^2}$$
We find:
$$x=\left(\frac{3}{5}\cdot6000 \right)^{\frac{1}{3}}\text{ in}=2\sqrt[3]{450}\text{ in}$$
$$h=\frac{5}{3}\cdot2\sqrt[3]{30}\text{ in}=\frac{10}{3}\sqrt[3]{450}\text{ in}$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
