I Total focal length and magnification
The discussion focuses on constructing a telephoto lens system to image a cantilever with dimensions of 450x50 microns, targeting a magnification between 4 and 8. It emphasizes that the image magnification is determined by the ratio of the focal lengths of two lenses, regardless of the total focal length. Questions arise about the relevance of total focal length when using different lens combinations that yield the same magnification, and whether the lensmaker's equation should be applied for calculating working distance. Additionally, there is a need for clarification on the setup, including the distances between the lenses and the sensor, and considerations for light collection and distortion in the imaging process. A detailed annotated diagram is suggested for better understanding and to facilitate more accurate responses.
Aymangh994
I would like to realize an image of the cantilever. The dimensions are (450x50) microns. I would like to use a self-constructed telephoto lens. This consists of two lenses. The image magnification can be 4 to 8. The magnification of the image is nothing more than the ratio between the two focal lengths of the two lenses. E.g. for f1= 320mm f2=40mm the total f= 35.5mm and the imaging magnification is 8 . Since typical focal lenghts of telephoto are over 50mm, I would like to ask if the total focal length matters? I.e. for f1= 800mm and f2=100mm the total focal length is f=88.89 mm but the image magnification remains the same.
Science news on Phys.org
You need to specify more about the set-up. What is "the cantilever"? We need an annotated diagram if you want sensible answers.
Edit: PS I think you are assuming the 'telescope formula' applies but your object distance is not infinite and are you looking at an image or projecting it onto a sensor?
Likes davenn and hutchphd
I would like to ask if the total focal length matters using two different combinations of lenses but the magnification still the same.
Combination 1 : f1= 320mm f2=40mm the total f= 35.5mm and M= 8
Combination 2 : f1= 800mm and f2=100mm the total focal length is f=88.89 mm and M= 8
and how to calculate the working distance ?
Sketch
following questions :
1. should I use the lensmaker's equation to calculate the working distance ? which focal length should I insert in the equation? the total f or f1 ?
2. The distance between the two lenses and the distance between the CCD-Sensor and the last lens ?
You seem to be using a telescope rather than a microscope. In such a case, the objective lens should be as large as possible to collect maximum light, but may have to be stopped down to reduce distortion. The required magnification is very small - can this be obtained with a single lens?
Thread 'Simple math model for a Particle Image Velocimetry system'
Hello togehter, I am new to this forum and hope this post followed all the guidelines here (I tried to summarized my issue as clean as possible, two pictures are attached). I would appreciate every help: I am doing research on a Particle Image Velocimetry (PIV) system. For this I want to set a simple math model for the system. I hope you can help me out. Regarding this I have 2 main Questions. 1. I am trying to find a math model which is describing what is happening in a simple Particle...
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
