MHB Transfer function of a damped hanging mass
To find the transfer function of a damped hanging mass system, the equations of motion for both masses must be correctly established. The input force \(u\) and the damping force \(F_d\) are defined, leading to the equations \(u - b(\dot{x}_1 + \dot{x}_2) = m(\ddot{x_1} + \ddot{x_2})\) and separate equations for each mass. The Laplace transforms yield equations that include both \(X_1(s)\) and \(X_2(s)\), complicating the derivation of the transfer function \(H(s) = \frac{X_1(s)}{U(s)}\). To isolate \(X_2(s)\), one approach is to express it in terms of \(X_1(s)\) using the established equations, allowing for simplification. The discussion emphasizes the need for careful modeling of the system dynamics to accurately derive the transfer function.
Dustinsfl
How do I find the transfer function of damped masses hanging?
I know that the transfer function is
H(s) = \frac{\mathcal{L}\{y(t)\}}{\mathcal{L}\{x(t)\}}
where \(u\) is the input which is a force and \(x_1\) is the output.
Given the following diagram (see below), how do I find the input and output functions?
http://imagizer.imageshack.us/v2/800x600q90/40/eh7q.png
Mathematics news on Phys.org
The force of damping is
F_d = b\frac{dx}{dt}
so by Newton's Law, the system can be written as
u - b(\dot{x}_1 + \dot{x}_2) = m(\ddot{x_1} + \ddot{x}_2).
Is this Correct?
How do I separate out the input from the output?
I tried modeling the forces separately but not sure if this is wise either.
For the first mass, we have $-b\dot{x}_1 = m\ddot{x_1}$, correct?
Now the second is $-b(\dot{x}_1 + \dot{x}_2) + u = m\ddot{x}_2$, correct?
I should be able to take the Laplace transform of both and end up with what I need to construct the transfer function which is
H(s) = \frac{X_1(s)}{U(s)}.
However, I still have and $X_2(s)$. Are my equations of motion wrong? If not, what am I doing incorrectly?
If take the Laplace transform of both, we have
X_1(s)(s^2m + bs) = 0
and
X_2(s)(s^2m + sb) + sbX_1(s) - U(s) = 0
The initial conditions are zero since when finding the transfer function, the initial conditions are zero by definition. If this is correct, how do I get rid of \(X_2(s)\)?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
