Comp Sci Transfering data from a text file into a 2D vector array in c++
The discussion focuses on transferring data from a text file into a dynamically sized 2D vector array in C++. The user is attempting to read a file containing numerical data and push each number into a vector of vectors. A compilation error arises because they are trying to push an `istringstream` object into a `vector<vector<string>>`, which is a type mismatch. The user also realizes that their vector declaration is incorrect, as it mistakenly uses parentheses, leading to an empty function declaration instead of a vector. The conversation emphasizes the importance of matching data types and correcting the vector initialization.
Absolutism
I am attempting to transfer the data from a file into a 2D vector array. The data look like this:
1 2 3
4 5 6
7 8 9
However, the dimensions must be detected dynamically.
There are two files in this code, but I attempted to transfer only one of them. I tried to read line by line and then take each word and push it into the array of vectors. The program does not compile though.
#include <iostream>
#include <fstream>
#include <string>
#include <sstream>
#include <vector>
using namespace std;
int main ( ) {
ifstream infile1;
ifstream infile2;
infile1.open ("Array.txt");
infile2.open ("Pattern.txt");
if (!infile1||!infile2) {cout<<"error"; return -1;}
string line; string word;
vector<vector<string>>a();while (!infile1.eof())
getline (infile1, line);
istringstream stringline (line);
while ( stringline >> word ) {
istringstream strw (word);
a.push_back(strw); //the error is here. The "a." specifically.
return 0;
Hi Absolutism! :smile:
You're trying to push_back() an istringstream onto a vector of vector<string>.
That's not possible.
The type does not match...
Btw, don't you get a compilation error on the following line?
Code:
Oh yes, I got it. Thank you!
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
