Transfinite Induction: Understanding & Examples
Transfinite induction is equivalent to standard induction on the ordinal number ω, as there are no limit ordinals smaller than ω. However, transfinite induction extends beyond ω, allowing proofs for ordinals greater than ω, which requires consideration of limit ordinals. An example illustrating the difference is the statement that every ordinal greater than 0 is a successor to a unique ordinal; this holds for ordinals less than ω but fails for ω itself. The necessity of a limit step in transfinite induction prevents the proof of false statements that can arise in standard induction. Overall, understanding the distinctions between these forms of induction is crucial for accurate mathematical reasoning.
Hjensen
I'm a bit confused on the subject of transfinite induction. I've read that it is equivalent to usual induction on the ordinal number ω (presumably a proof of this can be found in a standard book on the subject - any suggestions?)
Does anyone have an example of a case in which this isn't true? In other words where these two forms of induction do not coincide? I can't seem to think of one myself.
Perhaps I should clarify a few things. By ω I mean the least infinite ordinal, which is identified with \aleph_0.
The idea I have of the two notions being different relies on intuition only. If anyone has a concrete example, you would make my day. Especially if you could include a reference to a proof of the fact that transfinite induction is equivalent to regular induction on the ordinal ω
Transfinite induction allows you to use induction proofs over ordinals greater than \omega, ordinary induction only allows you to prove things over \omega. The key difference is that transfinite induction involves a limit case to take into account limit ordinals i.e. if the property holds for every ordinal before the limit ordinal then it must be shown that it also holds for limit ordinal.
To see why this is important consider the statement 'every ordinal greater than 0 is a successor to some unique ordinal'. This is true for ordinals less than \omega, but is not true in general, e.g. for \omega itself. However, the successor step in an induction proof will be trivially true, so to avoid 'proving' untrue things you need a limit step too for ordinals larger than \omega.
Transfinite induction is trivially equivalent to classical induction over \omega as there are no limit ordinals smaller than \omega.
Transfinite induction is very close in spirit to that of strong induction. You assume that a statement ##P(x)## is true for every ##x<a##, and then show it's true for ##x=a##. In typical induction, you are only concerned with the whole numbers, though in transfinite induction you instead look over any other ordinal. The basic mechanics of the approach is the same.
Hello, I'm joining this forum to ask two questions which have nagged me for some time. They both are presumed obvious, yet don't make sense to me. Nobody will explain their positions, which is...uh...aka science. I also have a thread for the other question. But this one involves probability, known as the Monty Hall Problem. Please see any number of YouTube videos on this for an explanation, I'll leave it to them to explain it. I question the predicate of all those who answer this...
I'm taking a look at intuitionistic propositional logic (IPL). Basically it exclude Double Negation Elimination (DNE) from the set of axiom schemas replacing it with Ex falso quodlibet: ⊥ → p for any proposition p (including both atomic and composite propositions). In IPL, for instance, the Law of Excluded Middle (LEM) p ∨ ¬p is no longer a theorem. My question: aside from the logic formal perspective, is IPL supposed to model/address some specific "kind of world" ? Thanks.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
