B Transform the system of trigonometric equations
To extract variables l and L from the given system of trigonometric equations, the first step is to eliminate the arctans. By taking the ratio of the equations, a relationship between tan l and sin L can be established. This relationship allows for the elimination of one variable from the equations. Participants confirm that this discussion is not related to a homework problem. The outlined method provides a clear approach to solving the equations.
Rmax
How to extract l and L from the following system of equations:
Mathematics news on Phys.org
Please confirm that this is not a homework problem.
First step is to get rid of the arctans in the obvious way. Then taking the ratio you can get an equation relating tan l to sin L. You can use that to eliminate one of them from one of the equations.
No, it is not a homework.
Ok, so can you follow the steps I posted?
I'll definitely try, thank you!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
