Transformation function from ground state -> nth energy state, force applied, HO
The discussion revolves around solving a quantum mechanics problem from L. Brown's Quantum Field Theory, specifically calculating the probability of transitioning from the ground state to the n-th energy state under an external force. The user outlines their approach, utilizing coherent states and the time-evolution operator to derive the necessary transformations. They express concerns about the clarity of their notation, which may be hindering responses from others in the forum. Suggestions are made to improve their equation formatting using LaTeX for better comprehension. Overall, the thread highlights the complexities of quantum state transformations and the importance of clear communication in technical discussions.
Imanbk
Hello Everyone!
I have a question regarding a Quantum problem I am trying to solve in L. Brown's Quantum Field Theory book, Chapter 1, Problem 4.f.
I have a question which asks me to compute [p][/n], i.e. the probability that the ground state (n=0) is brought to the n-th energy state with the effect of an applied external force f using the transformation:
[<z*, [t][/2]|0,[t][/1]>][/f] ,
Where z* is a coherent state eigenvalue. Here is the problem statement:
Use [<z*, [t][/2]|0,[t][/1]>][/f] as a generating function to compute:
[<n, [t][/2]|0,[t][/1]>][/f] , and hence the probability that the force changes the ground state into the n-th energy eigenstate,
[p][/n]= [|[<n, [t][/2]|0,[t][/1]>][/f]|][/2]
The relevant equations are the equations given above, and the result I got for [<z*, [t][/2]|0,[t][/1]>][/f]. The book states that the answer for <z*, [t][/2]|0,[t][/1]> should have the form:
<z*, [t][/2]|0,[t][/1]> = <z*|Z>f(Z).
To arrive at the solution for the transformation of z* -> 0 with f=0 (why? Well, it wasn't stated otherwise so I assume f=0 in <z*, [t][/2]|0,[t][/1]>), I take out the time dependence by writing the time-evolution operator, U([t][/2], [t][/1]) = exp{-i[H][/n]([t][/2]-[t][/1])}, since there is no force the Hamiltonian is time-independent.
Than I act [H][/n] (where H is an operator) on the |0> energy state and this rids the equation of any time dependence. So I get:
<z*, [t][/2]|0,[t][/1]> = <z*|0> .
Now to get the form required, I write the |0> state as a coherent state using
exp{Za}|0>= |Z> hence |0> = exp{-Za}|Z>, than I expand the exponential, and than act [a][/+] on <z*|, and I get:
<z*, [t][/2]|0,[t][/1]> = exp{-z*Z} <z*|Z> = 1.
The first thing I do to solve the current problem is use the resolution of the identity for coherent states to decompose [<n, [t][/2]|0,[t][/1]>][/f] into two parts, one of which is [<z*, [t][/2]|0,[t][/1]>][/f] and the other is [<n, [t][/2]|z,[t][/2]>][/f].
We have right away that [<n, [t][/2]|z,[t][/2]>][/f] = [<n|z>][/f] since the bra and ket are evaluated at the same time (i.e. the time evolution operator is integrated from time t2 to time t2, hence equals the exponential of zero. the second term is slightly more complicated. It now involves a time-dependent hamiltonian because there is an applied force, and hence the time-evolution operator will be written as the time integral of the hamiltonian.
I write the time-evolution operator in terms of H([a][/+], a) (i.e. in terms of the annihiliation and creation operators. I use H=/omega*([a][/+]*a+1/2) - f/sqrt(2)*([a][/+]+a) as was asked in part b) of the same problem, and I act the with the annihilation and creation operators on the <z*| and |0> states. I can show the steps if requested (because my post is getting quite long), but the rest is just acting on the states, putting both transformation functions together under the dzdz*/(2*pi*i) exp{-z*z} integral, simplifying the expression, and making a change of variables to compute each integral. I get the product of two integrals at the end. One looks like a gamma function, except that the integral bounds are from -\infty to \infty instead of 0 to \infty and the integrand is not an even function. And the other integral converges but I don't recognize the form of the integral.
Can someone please let me know if I'm on the right track and/or let me know if the integrals sound like they are in the correct form? Or let me know of a reference which might help me with my problem? If something isn't clear in the question or my approach kindly let me know.
Thank you very much,
imanbk
Hello,
I found one way to do it which requires changing the Schrodinger representation into the Heisenberg representation and writing
p_n(t) = <n|0>^(f) *<0|n>^(f) = <0| P_n(t)|0>^(f),
where p_n(t) is the probability that the force changes the ground state into the n-th energy state.
After making a change to the Heisenberg picture I use the Hamilton equations of motion for the annihliation and creation operators resp. and solve for a(t), a^+(t). I than use normal ordering to order P_n(t) and computer p_n(t) with the time-dependent a and a^+ I computed.
Can someone please let me know why my posts never get answered? Is it because of the form I write the equations in? If this is the problem, can someone explain to me what I can use to write the equations using something the forum provides? I tried using the subscript and superscript bottons but those didn't print out the way they should.
Thank you for replying about the possible problem of why I don't get replies to my post.
It's probably because your notation is unfamiliar and thus confusing. You might take a look at the FAQs pointed to at the top of the forum to learn how to use LaTeX and the forum typesetting features to make your post easier to understand.
Thank you vela for your reply! I'll try it out :)
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
