Transition dipole -- Line shape function
In summary: This may be a hard task. However, in some situations, there are simplifications that can be made to this process. But I can't answer this without knowing the specific system.In summary, the classical approach of using a "transition dipole oscillation" to explain the broadening of spectrum of emission between energy levels is based on the idea of an electron-proton pair oscillating to emit a photon. The lifetime of an orbital is defined as the sum of all transition rates to other possible orbitals. It is not clear if electrons can jump to higher or lower orbitals without giving up energy, and this transient behavior is not well-studied. The Kronig-Penney model of solid state physics, which uses bands instead of
Goodver
102
I am confused with the classical approach of usage of a "transition dipole oscillation" in order to explain the broadening of spectrum of emission between energy levels.
1. If I understand it correctly then emission of photon is due to oscillation of a dipole consisting of an electron-proton pair, right? In this case, electrons just oscillate on orbitals but do not change their orbitals? Or electrons also jump to the higher and lower orbitals? If they change, then electron oscillates on its way from one orbital to another?
2. Lifetime defined as a time until electron oscillation gets damped, but electron stay on its orbital or time takes for electron to transit from one orbital to another? What determines the different lifetimes for different atoms?
3. Why broadening of a spectrum can not be explain with a solid state physics concept of Kronig-Penney model, where we have bands instead of level in a multi atomic system?
4. Why dipole can oscillates only with a frequency corresponding to the energy difference between energy levels?
Picture taken from this thread:
Thank you.
That's a classical, non (fully) quantum view.
In the present of perturbation such as external field, the true wavefunction of the electron can be represented as a linear combination of the unperturbed Hamiltonian eigenfunctions. So the expectation value of some observables such as radius is indeed time-dependent, but to say whether it either stays definitely in its orbital or change to another one is actually violating the QM postulate. As said above that the electron state can be expanded into superposition of the orbitals' wavefunction means that it has less-than-unity probability of ending up in various orbitals. In fact the lifetime of a given orbital is defined as the sum of all transition rates from that orbital toward the other possible orbitals
Is there any way an electron can change orbital with different energies without giving up its energy into some other form?
I'm not sure that there has been research which studies such transient behavior. You may want to look on this matter up yourself. Otherwise, to study this with sufficient accuracy, one should probably calculate the perturbed state up to some higher perturbation order.
FAQ: Transition dipole -- Line shape function
1. What is a transition dipole?
A transition dipole is a vector quantity that describes the strength and orientation of an electric dipole moment between two energy states in an atom or molecule. It is a fundamental concept in spectroscopy and is used to understand the absorption and emission of electromagnetic radiation by matter.
2. How is the transition dipole related to line shape function?
The transition dipole is a key factor in determining the shape of spectral lines in a spectrum. The line shape function describes the distribution of energy levels and their corresponding transition probabilities. The transition dipole determines the magnitude of these transition probabilities, and thus influences the overall line shape.
3. How does the transition dipole affect the intensity of spectral lines?
The transition dipole moment is directly proportional to the intensity of a spectral line. This means that a larger transition dipole will result in a stronger absorption or emission of radiation, and a higher intensity line in the spectrum.
4. Can the transition dipole change over time?
Yes, the transition dipole can change over time. This can occur due to changes in the electronic structure of the atom or molecule, such as in the case of photoexcitation or chemical reactions. The transition dipole is also affected by external factors such as temperature and pressure.
5. How is the transition dipole calculated?
The transition dipole can be calculated using a variety of theoretical and experimental methods, depending on the specific system being studied. In general, it involves calculating the difference in electronic charge distribution between the two energy states involved in the transition, and taking into account the orientation of the molecule.
