MHB Triangle Questions: Get Expert Advice Now
  • Thread starter Thread starter wailingkoh
    Triangle
The discussion revolves around solving two triangle-related questions, focusing on calculating areas. Participants confirm that if two triangles have equal base lengths and heights, their areas will also be equal. The conversation includes attempts to find the area of a larger triangle and subtract the area of a smaller triangle formed by a semi-circle. The final calculations lead to a formula for the area based on the radius of the semi-circle, resulting in a specific area value when the radius is given. The thread concludes with a successful resolution of the area calculations.
wailingkoh
Mathematics news on Phys.org
If the length of the base and the height of two triangles are equal then their area is equal.
Hi there,
Thanks, how about the other question?
wailingkoh said:
Hi there,
See if the following diagram inspires you...
Find the big tri and subtract?
But I won't be able to find the big tri
Yes, but you do know the base and altitude of the big triangle, based on the diameter of the semi-circle. :D
Hmm, how to find the green part?
- - - Updated - - -
Arr...1/2 *30*18 for the big Triangle. But the green part, what do I do??
- - - Updated - - -
- - - Updated - - -
Arr...1/2 *30*18 for the big Triangle. But the green part, what do I do??[/QUOTE
The small green tri has an arc to it formed by a a semi circle
Take the area of the square, and subtract away the red area of the quarter circle...:D
Awesome! Got it and thanks for the help
I would let $r$ be the radius of the semi-circle, and so the area $A_T$ of the big triangle in my first diagram would be:
$$A_T=\frac{1}{2}(3r)(r)=\frac{3}{2}r^2$$
Now, the green area $A_S$ to be subtracted away is:
$$A_S=r^2-\frac{1}{4}\pi r^2=r^2\left(1-\frac{\pi}{4}\right)$$
And so the area $A$ we are asked to find is:
$$A=A_T-A_S=\frac{3}{2}r^2-r^2\left(1-\frac{\pi}{4}\right)=r^2\left(\frac{1}{2}+\frac{\pi}{4}\right)=\left(\frac{r}{2}\right)^2(2+\pi)$$
Now, we are given $r=9\text{ cm}$, hence:
$$A=\left(\frac{9\text{ cm}}{2}\right)^2(2+\pi)=\frac{81}{4}(2+\pi)\text{ cm}^2$$
