MHB Tricky Logic Puzzle with 26 Variables
The logic puzzle involves finding the product of the expression (x-a)(x-b)(x-c)...(x-z). While it appears complex, the solution is straightforward when recognizing that the variables a to z represent letters of the alphabet. The key insight is that if any variable equals x, the entire product equals zero. This classic puzzle highlights the importance of recognizing patterns in mathematical expressions. Ultimately, the answer simplifies to zero when any variable matches the value of x.
Tompson Lee
Can you figure out what the answer of (x-a)(x-b)(x-c)...(x-z) is?
This problem seems very tricky and you might think you need to expand one by one, but if you think carefully, you will find out that the answer is very simple!
Solution:
[YOUTUBE]CnHBE4SbRRs[/YOUTUBE]
Mathematics news on Phys.org
That's an old classic puzzle.
I remember someone programming a looper program
to solve this puzzle, but gave up saying:
"I give up: I keep getting zero no matter what"!
I didn't realize that (x - x) until Denis McField gave the hint...
This trick puzzle is usually presented this way:
(a-n)*(b-n)*(c-n)* ... *(x-n)*(y-n)*(z-n) = ?
Using "n" makes it look more authentic,
since "n" is part of most sequence formulas.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
