Tricky V I Graph Need help please
  • Thread starter Thread starter Steve12345
    Graph
The discussion revolves around determining the gradient of a graph related to voltage (V) and current (I) measurements across a battery. Participants clarify that as the load resistor value decreases, the loop current increases, leading to a decrease in measured source voltage due to internal resistance. The confusion arises regarding whether the slope of the graph should be positive or negative since the voltmeter measures across the battery. It is emphasized that the graph should reflect the relationship defined by the equation V = emf - I*r, which corresponds to the battery's internal resistance. Ultimately, the participants encourage the poster to clarify their graph construction based on these principles.
What do you mean by 'gradient'?
You might consider taking more than 1 measurement of I and V ...
Steve12345 said:
need help with this question, is the gradient negative or positive since the voltmeter is over the battery?
Here is the image (sorry for making you tilt your heads)https://www.dropbox.com/sh/v6ydqbfrg20whtb/ZWR-r9ZOSH?lst#f:q17.JPG
As the load resistor value gets smaller, the loop current increases, and the measured source voltage decreases because of the increasing voltage drop across the voltage source's internal resistance.
Does that make sense? Can you now show us your work on the graph?
I drew a line that made a triangle from the V axis to the I axis, so when the current was at its highest V was 0 and when V was at its highest I was 0, so it was a negative slope.
I used emf= V+Ir and rearranged it go get emf - Ir = V. I am confused at wether the graph should be the a positive slope since the voltmeter is measuring the battery and not the load resistor if you get where I am coming from
So I am saying I drew it like this http://www.s-cool.co.uk/a-level/assets/learn_its/alevel/physics/Resistance/internal-resistance-emf-and-potential-difference/Finding%20the%20internal%20resistance.gif
Does it make a difference to the graph that were measuring V at a different point
Your graph is fine as far as it goes.
I don't understand your question abot V being measured "at a different point". The problem shows exactly where V is measured - across the battery including its internal resistance. Your equation V = emf - I*r fully corresponds to the diagram of the problem.
Now, how do you propose to construct your graph? You don't know emf or r. You're supposed to use the graph to determine emf and r.
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up will act downwards and maximum static friction will act downwards Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
