MHB Trig proof: sum of squared cosecants
  • Thread starter Thread starter Greg
    Proof Sum Trig
The discussion focuses on proving the equation involving the sum of squared cosecants: $$\csc^2\left(\dfrac{\pi}{7}\right)+\csc^2\left(\dfrac{2\pi}{7}\right)+\csc^2\left(\dfrac{4\pi}{7}\right)=8$$. Participants suggest using the roots of a polynomial derived from the equation $\tan\, 7x = 0$, leading to a sixth-degree polynomial. The roots correspond to $\cot^2 nx$, and the sum of these roots is calculated to be 5. By adding 1 to each term in the left-hand side, the desired result is obtained. The conversation highlights the application of trigonometric identities and polynomial roots in solving the problem.
Greg
MHB
Hi! I've tried a couple of approaches with this: converting to complex exponential form and using standard trigonometric identities but have been unable to solve. I suspect DeMoivre's formula applies but I don't see how.Prove $$\csc^2\left(\dfrac{\pi}{7}\right)+\csc^2\left(\dfrac{2\pi}{7}\right)+\csc^2\left(\dfrac{4\pi}{7}\right)=8$$
Mathematics news on Phys.org
you should be able to solve with the following approach ( if there is a problem I shall provide solution tomorrow)
using $\tan\, 7x = 0$ you can find the solution $\tan\, nx$ to be root of $t^6-21t^4+35t^2-7=0$
form the eqaution whose roots are $\frac{1}{t^2}$
you should have the roots $\cot^2 nx$
from this should know the sum of $\cot^2 nx$
add 1 to each term and get the result
I don't understand how to derive this result.
from the series expansion of $\tan (2n+1) x$ we have
$\tan 7x = \dfrac{\tan ^7 x -21\tan ^ 5x + 35tan^3 x - 7\ tan\, x }{7\tan^6 x - 35 \tan ^4 x + 21 \tan ^2 x -1}$
as $\tan7x = 0$ for $x = \dfrac{n\pi}{7}$ n = 0 to 7 so
$\tan\,nx$ is root of$t^7 -21t^5 + 35t^3 - 7t= 0 $
as for n = 1 to 6 $\tan\, nx$ is not zero so
n = 1 to 6 $\tan\, nx$ is root of $t^6 -21t^4 + 35t^2 - 7= 0$
$\cot \, nx$ is root of $(\dfrac{1}{t})^6 -21(\dfrac{1}{t})^4 + 35(\dfrac{1}{t})^2 - 7= 0 $
or $7t^6-35t^4 +21t^2 -1=0$
so $\cot^2 nx$ is root of equation $7t^3 - 35 t^2 + 21 t - 1$ = 0
now $\cot^2 x = \cot^2 6x$
$\cot^2 2x = \cot^2 5 x$
$\cot^2 3x = \cot^2 4x$
so the roots are $\cot^2 x,\cot^2 2x,\cot^2 4x$
so we get sum of roots
$\cot^2 x + \cot^2 2x + \cot^2 4x = 5$ and adding 1 to each term on LHS you get the result
edit: I remembered that I have solved a similar problem at http://mathhelpboards.com/challenge-questions-puzzles-28/cotangent-sum-16172.html
and you can put n = 3 to get the result.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
