Trigonometric equality sin15°sin24°sin57°=sin39°sin27°sin18°
In summary, we can prove that $\sin 15^\circ \sin 24^\circ \sin 57^\circ= \sin 39^\circ \sin 27^\circ \sin 18^\circ$ by using the sum-and-product trig formulas and the geometry of a pentagon.
anemone
MHB
POTW Director
3,883
115
Prove $\sin 15^\circ \sin 24^\circ \sin 57^\circ= \sin 39^\circ \sin 27^\circ \sin 18^\circ$.
This is an unsolved problem I found @ AOPS.
Mathematics news on Phys.org
[sp]Using the sum-and-product trig formulas, $$\begin{aligned}\sin 15^\circ \sin 24^\circ \sin 57^\circ &= \sin 15^\circ\cdot\tfrac12\bigl( \cos 33^\circ - \cos 81^\circ\bigr) \\ &= \tfrac14\bigl( \sin 48^\circ - \sin 18^\circ - \sin 96^\circ + \sin 66^\circ\bigr),\qquad(1) \\ \\ \sin 39^\circ \sin 27^\circ \sin 18^\circ &= \sin 39^\circ\cdot\tfrac12\bigl( \cos 9^\circ - \cos 45^\circ\bigr) \\ &= \tfrac14\bigl( \sin 48^\circ + \sin 30^\circ - \sin 84^\circ + \sin 6^\circ\bigr). \qquad(2)\end{aligned}$$
Comparing (1) and (2), they both contain $\sin 48^\circ$. Also, $\sin 96^\circ = \sin 84^\circ$ (because the sine function is symmetric on either side of $90^\circ$). So to show that (1) and (2) are equal, we need to prove that $\sin 66^\circ - \sin 18^\circ - \sin 6^\circ = \sin 30^\circ = \frac12.$ But $$\sin 66^\circ - \sin 6^\circ = 2\cos 36^\circ \sin 30^\circ = \cos 36^\circ = \sin 54^\circ.$$
Therefore it remains to show that $\sin 54^\circ - \sin 18^\circ = \frac12.$ The nicest way to do that is to use the geometry of the pentagon.
[TIKZ]
\coordinate [label=above: $C$] (C) at (90:5cm) ;
\coordinate [label=above right: $D$] (D) at (18:5cm) ;
\coordinate [label=above left: $B$] (B) at (162:5cm) ;
\coordinate [label=below: $A$] (A) at (234:5cm) ;
\coordinate [label=below: $E$] (E) at (306:5cm) ;
\coordinate [label=below: $P$] (P) at (-4.755,-4.045) ;
\coordinate [label=below: $Q$] (Q) at (4.755,-4.045) ;
\draw (A) -- node
{$1$} (B) -- node[above left] {$1$} (C) -- node[above right] {$1$} (D) -- node
{$1$} (E) -- node[below] {$1$} (A) ;
\draw (A) -- (P) -- (B) -- (D) -- (Q) -- (E) ;
\draw (C) -- (0,1.545) ;
\draw (-3.4,-3.75) node {$72^\circ$} ;
\draw (3.45,-3.75) node {$72^\circ$} ;
\draw (-5.1,0.8) node {$18^\circ\to$} ;
\draw (5.1,0.8) node {$\leftarrow18^\circ$} ;
\draw (-0.35,4.3) node {$54^\circ$} ;
\draw (0.4,4.3) node {$54^\circ$} ;
[/TIKZ]
In the diagram, $ABCDE$ is a regular pentagon with sides of length $1$, and $PBDQ$ is a rectangle. It is clear from the given angles that $BD = 2\sin 54^\circ$ and that $PQ = 1 + 2\sin 18^\circ$. Therefore $2\sin 54^\circ = 1 + 2\sin 18^\circ$, from which $\sin 54^\circ - \sin 18^\circ = \frac12.$[/sp]​
FAQ: Trigonometric equality sin15°sin24°sin57°=sin39°sin27°sin18°
What is the concept behind trigonometric equality?
Trigonometric equality refers to the concept that two trigonometric expressions are equal to each other, regardless of the values of the angles involved. This is based on the fundamental trigonometric identities and the properties of trigonometric functions.
How do you solve a trigonometric equality problem?
To solve a trigonometric equality problem, you must use algebraic manipulation and the properties of trigonometric functions to simplify the expressions on both sides of the equation. Once the expressions are simplified, you can compare and determine if they are equal or not.
What is the significance of the given expression sin15°sin24°sin57°=sin39°sin27°sin18°?
This expression represents a special case of trigonometric equality known as the Triple Angle Formula. It is used to simplify trigonometric expressions involving multiple angles, and it has many applications in mathematics and physics.
Can you use a calculator to solve this trigonometric equality problem?
Yes, you can use a calculator to solve this problem. However, it is important to understand the underlying concepts and steps involved in solving trigonometric equalities, rather than relying solely on a calculator.
What are the possible solutions to this trigonometric equality problem?
There are infinite solutions to this problem, as the equality holds true for any values of the angles involved. Some common solutions include using the Triple Angle Formula to simplify the expressions, or converting the expressions to their equivalent forms using other trigonometric identities.
