Trigonometric Identity Questions
In summary, the conversation discusses the identity of $\sin\theta = \frac{1}{\csc\theta}$ and its validity when both sides are defined. It also mentions the use of limits and composite angle formulas to prove this identity. Additionally, the conversation touches on the concept of infinity and how it should be approached when evaluating functions. Ultimately, it is recommended to politely refuse to evaluate a function at a point where it is undefined.
suzy1231
Your help will be greatly appreciated!
Thanks!1. The expression \(\sin\pi\) is equal to \(0\), while the expression $\frac{1}{\csc\pi}$ is undefined. Why is $\sin\theta=\frac{1}{\csc\theta}$ still an identity?
2. Prove $\cos(\theta + \frac{\pi}{2})= -\sin\theta$
Mathematics news on Phys.org
Use the addition formula together with the values from the unit circle \(\displaystyle \cos(A+B) = \cos(A)\cos(B) - \sin(A)\sin(B)\)
Welcome to MHB, suzy123! :)
It's an identity when both are defined.
And if you treat $\csc\pi$ as $\infty$ it even holds there.
An excellent point. Also, another way of looking at both is by considering limiting values:\(\displaystyle \lim_{x \to \pi}\sin x=0\)
\(\displaystyle \lim_{x \to \pi}\csc x = \lim_{x \to \pi}\frac{1}{\sin x}=\frac{1}{ \lim_{x \to \pi}\sin x } = \lim_{z \to 0 }\frac{1}{z} \to \frac{1}{0} \to \infty\)Similarly, you could use the composite angle formula I Like Serena gave above,
\(\displaystyle \sin (x \pm y)= \sin x \cos y \pm \cos x \sin y\)
and consider the limits\(\displaystyle \sin \pi = \lim_{x \to \pi}\sin x= \lim_{\epsilon \to 0}\sin (\pi \pm \epsilon) \to 0\)and\(\displaystyle \csc \pi = \lim_{x \to \pi}\csc x= \lim_{\epsilon \to 0} \frac{1}{\sin (\pi \pm \epsilon)} \to \infty\)
Prove that the function:
$f(\theta) = \sin\theta\csc\theta$
has removable discontinuities at $k\pi,\ k \in \Bbb Z$.
It is, by and large, problematic to simply say:
$\infty = \frac{1}{0}$ because such an assignment does not obey the algebraic rules of the real numbers (in particular, the cancellation law:
$ac = bc \implies a = b$ when $c \neq 0$
breaks down).
While it *is* possible to extend the real numbers in various ways to include the notion of infinity, it is usually preferable to phrase statements about infinity in ways that do not mention infinity itself such as:
instead of:
$\displaystyle \lim_{x \to a} f(x) = \infty$
we say:
for any $N > 0$, there is some $\delta > 0$ such that for all $0 < |x - a| < \delta$, we have $f(x) > N$.
This is a fancy way of saying: $f$ increases without bound near $a$. Note it does not mention infinity, nor does it say what (if any) value we should ascribe to $f(a)$.
As others have mentioned, the cosecant function is undefined at certain points. If one is asked to evaluate cosecant at such a point, one ought to politely refuse.
Genius! :cool:
FAQ: Trigonometric Identity Questions
What are Trigonometric Identities?
Trigonometric identities are mathematical equations that involve trigonometric functions (such as sine, cosine, and tangent) and are always true for all values of the variables. They are used to simplify and solve trigonometric equations and can also be applied in various real-life scenarios.
How many types of Trigonometric Identities are there?
There are three main types of Trigonometric Identities: reciprocal identities, co-function identities, and Pythagorean identities. Reciprocal identities relate one trigonometric function to another, co-function identities relate the values of trigonometric functions for complementary angles, and Pythagorean identities involve the Pythagorean theorem.
How do I prove a Trigonometric Identity?
To prove a Trigonometric Identity, you need to manipulate one side of the equation using algebra and trigonometric identities to make it equal to the other side. This is done by applying basic trigonometric rules, such as the sum and difference formulas, double-angle formulas, and half-angle formulas.
How are Trigonometric Identities useful in solving problems?
Trigonometric Identities are useful in solving problems because they allow us to simplify complex trigonometric expressions and equations. This makes it easier to solve for unknown variables and find solutions for real-life problems involving angles and distances, such as in navigation, engineering, and physics.
What are some common mistakes to avoid when using Trigonometric Identities?
Some common mistakes to avoid when using Trigonometric Identities include forgetting to use the correct sign for the trigonometric function, not simplifying expressions completely, and using the wrong identity for a given problem. It is also important to keep track of any restrictions on the values of the variables, as some identities may not be valid for certain values.
