MHB Trigonometric sum with a product as the argument
The discussion focuses on proving the trigonometric identity involving the sum of cosines. A user suggests starting with the left-hand side (LHS) and multiplying by \(2 \sin \frac{x}{2}\) to facilitate a telescopic sum. This approach leads to a simplification where the sum can be expressed as a difference of sine functions, allowing for cancellation. Ultimately, this method successfully reduces the expression to match the right-hand side (RHS) of the equation. The proof is confirmed as correct by another participant in the discussion.
Greg
MHB
Prove
$$\sum_{n=0}^N\cos(nx)=\csc\left(\dfrac x2\right)\sin\left(\dfrac{(N+1)x}{2}\right)\cos\left(\dfrac{Nx}{2}\right)$$
I've tried working from the RHS with various identities but haven't managed to come up with anything that works. I suspect this problem involves some trigonometry that I don't already know; if someone could post a solution or offer guidance on how to get started I'd be grateful. :)
Mathematics news on Phys.org
greg1313 said:
Prove
Let $S= \sum_{n=0}^N\cos(nx)$
multiply by $2 \sin \frac{x}{2}$ to get the reason I want it to be reduced to telesopic sum) ( sin x/2 for telescopic sum and 2 times to avoid fraction in result
$2S\sin \frac{x}{2} \sum_{n=0}^N\cos(nx) 2 \sin \frac{x}{2}$
or $2S\sin \frac{x}{2} = \sum_{n=0}^N(\sin(nx + \frac{x}{2}) - \sin(nx - \frac{x}{2}))$
the above can be added as it is telecopic sum and then reduced to RHS
That does it! Thank you very much, kaliprasad.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
