Trigonometry problems for NYSE regents
  • Thread starter Thread starter priscilla98
    Trigonometry
The discussion focuses on solving a trigonometry problem from the NYSE Regents exam involving a right triangle with given side lengths. The angle K can be found using the inverse cosine function, specifically cos^(-1)(5/6), which yields approximately 33.55730976 degrees. To convert this decimal into minutes, the fractional part (0.55730976) is multiplied by 60, resulting in the minutes needed for a precise angle measurement. The conversation emphasizes the importance of calculator functions for converting degrees to minutes and seconds. Overall, the solution process highlights both the mathematical approach and practical calculator use for accuracy.
priscilla98
In the diagram below, KW = 6, Kt = 5 and m<KTW = 90. What is the measure of angle K, to the nearest minute? Below is the website for this question because this is one of the questions from the algebra 2 and trigonomentary. This is question 23.
http://www.nysedregents.org/a2trig/20100615exam.pdf
SOH CAH TOA
I know if you use the inverse of cosine in this problem you can get the degrees of K. For ex, cos (inverse) (5/6) = 33 degrees but I'm confused on how to get the minutes.
You need to obtain more accuracy from the value of cos^{-1}(5/6)
Your calculator display should give something like 33.55730976 if set to degrees. A minute (denoted by ') is defined as being 1/60 of a degree, so 33o30' is the same as 33.5o because 30 is half of 60.
33o45'=33.75o
etc.
Your calculator should have a button that can convert decimals to minutes and seconds (a second is a 60th of a minute - thinking of degrees as being hours should make it easily memorable), but if you can't find this button, it can quickly be done with a bit of thinking.
We have 33.55730976 and we need to convert this into the form 33ox' to the nearest x. So all we have to deal with is the 0.55730976. Since a minute is 1/60 of a whole, then we have x/60=0.55730976. Now you have your minutes after you round off :smile:
Thanks a lot. have a good day :)
You too priscilla :smile:
  • · Replies 19 ·
  • · Replies 26 ·
9K
