Triple integral in spherical coordinates
hitemup
Evaluate
\int \int \int _R (x^2+y^2+z^2)dV
where R is the cylinder
0\leq x^2+y^2\leq a^2,
0\leq z\leq h
[/B]
x = Rsin\phi cos\theta
y = Rsin\phi sin\theta
z = Rcos\phi
[/B]
2*\int_{0}^{\pi/2}d\phi \int_{0}^{2\pi}d\theta \int_{0}^{h/cos\phi}dR R^4sin\phi
Are the bounds correct?
Do you have to use spherical co-ordinates, why not cylindrical ones ?
hitemup said:
Evaluate
0\leq z\leq h
[/B]
z = Rcos\phi
[/B]
This is not set properly if you insist on using spherical coordinates. You would have to break it up into two integrals, one where ##\rho## goes from ##0## to the side of the cylinder and another where it goes from ##0## to the top. A much better choice is cylindrical coordinates. Try setting it up that way and check back with us.
Yes I realized at one time it would be easier if I used cylindrical coordinates, since the region itself is a cylinder. But I just wanted to know how to proceed with spherical coordinates.
Likes Noctisdark
OK, so give it a go. First set up$$
\int_{\theta \text{ limits}}\int_{\phi \text{ limits}}\int_0^{\rho \text{ on the sides in terms of } \phi} \text{Integrand }
\rho^2\sin\phi~d\rho d\phi d\theta$$then add$$
\int_{\theta \text{ limits}}\int_{\phi \text{ limits}}\int_0^{\rho \text{ on the top in terms of } \phi} \text{Integrand }\rho^2\sin\phi~d\rho d\phi d\theta$$
EDIT : Sorry, i thaught they were cylindrical
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
