Trouble Understanding RLC Circuits: Detailed Explanation for 250W Power Release
Understanding RLC circuits requires grasping the relationship between voltage, current, and impedance. To achieve 250 W of power with an effective voltage of 120 V, one must first calculate the necessary current through the resistor using the formula P = I^2 R. The impedance of the circuit, which varies with frequency, must also be considered to determine the current. The equations P = VIcos(phi) and P = V^2/Z can be applied to find phase angle and reactance, respectively, while it's important to remember that inductors and capacitors do not dissipate energy. Mastering these concepts involves approaching the problem from multiple angles and reinforcing foundational knowledge.
Juraj
I'm having real trouble understanding some concepts in RLC circuits.
If I have a circuit like this. The effective voltage is 120 V. What is the required frequency for resistor to release power of 250 W?
I want to really understand this on a deeper level so please make the explanation detailed. I know that the power is P = VI but what voltage should (maximum or effective) I use, what current? How to calculate current if I have voltage? Why can't I just use P = V^2/R or P = V^2/Z? I'm really bothered by this and AC circuits seem very complicated. And what about the voltage drop in series circuit, does that affect the result?
And also, when is P = VIcos(phi) used? Can i use it here? And what if I wanted to calculate the energy released by the inductor or capacitor?
I think you are lost in the equations. The V that you need is what occurs across the resistor. Not having that, go with the power equation in terms of current.
A better way to start is to ask - what value of current will deliver 250 W through the resistor? Watts = I^2 R
So now we have the current. You have an impedance that is complex and will change depending on frequency.
You need to write out the components of the impedance as a function of frequency. The magnitude of the impedance is Z.
With an effective voltage of 120 V and an impedance of Z, write the equation for the current.
You already understand more than you think you do. Just you're looking for an instant one step solution.
Authors of textbooks try to make you think in steps . So they give you problems that require two or more of them.
There's several ways to approach this one, and you should work it a few times coming at it from different angles.
I'd say first, as magoo suggested , figure what must be the current through the resistor , and then what must be the total impedance of the circuit to result in that much current. Pythagoras will tell you the reactance necessary, so at what frequency does 185 mh and 65 uf make that reactance?
Inductors and capacitors do not dissipate energy - go back to your basics.
Now that's interesting. 250 = 120 X current X cos(phi) gives you phi... Pythagoras again ?See, you knew that already didn't you ?
Much of learning is discovering what we already know.
Have you learned rectangular and polar notation yet ? That's the mental muscle this exercise is trying to build.
old jim
Likes sophiecentaur and cnh1995
It seems more clear now, thanks!
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
