Gothican
- 21
I've been reading Brian Greene's book 'The Fabric of the Cosmos', and had a little trouble in the part where he explains bell's discovery regarding the EPR paradox.
Bell's discovery in short was that there is a way to check if a particle has a definite spin about more than one axis or not; He prepared two detectors which measured the direction of the spin of two identical particles on three different axis', each 120 deg. apart (CW or CCW). Therefore, there are 9 different combinations of axis' the two detectors measure: (1,1),(1,2),(1,3) ... (3,3) while each number stands for the 3 different axis.
Now, according to EPR, the particles have definite spins about every axis, and the both of them are "programmed" before they leave the source. -> the universe IS local.
Therefore, the two detectors should find compatibility with the two particle's spins when they check the two particles about the same axis ((1,1),(2,2),(3,3)), and two more times because there are three axis' and only two different results - CW and CCW ((1,2),(2,1)). - 5 times out of 9.
Hope you guys got the picture.
Now my question is, what is the quantum expectation in this experiment?
I know that it's 50 percent of the time (as opposed to more than 50 per. according to EPR), but why?
What happens to the two particles if you check one's spin on one axis and then the second on another? If QM tells us that one of the particles makes the other immediately fixate upon one axis, and jump out of it's state of uncertainty, you shouldn't be able to measure the second's spin at all! Then what does the second detector find?
Thanks in advance,
Gothican
Thanks in advance,
Gothican
