Troubleshooting a 350 Ohm Strain Gauge Installation
The user is troubleshooting a 350 ohm strain gauge installation, specifically the CEA-13-125UN-350 model, and is encountering an issue where they are not getting the expected 350 ohms between terminals 1 and 2, despite passing other terminal checks. They have verified the connections multiple times and received confirmation from peers that the setup appears correct. The user expresses frustration, feeling that the problem defies physics, and emphasizes that they believe the strain gauge itself is not at fault. Additional requests for specifications and details about the assembly indicate that the setup may be more complex than initially assumed. The discussion highlights a perplexing issue in strain gauge installation that remains unresolved.
Matt2015
Hello,
I was wondering if anyone can help me out with this one. I am installing a 350 ohm strain gauge as shown in attached figure. I am expecting to see 350ohm value between terminal 1 and 2. I have checked the values for the following terminals.
1) 5 & 6 = 350ohm (PASS)
2) 3 & 4= 350ohm (PASS)
3) 3 & 2= 350ohm (PASS)
4) 4 & 1= 350ohm (PASS)
5) 5 & 1= 0.03ohm (CLOSED LOOP) (PASS)
6) 6 & 2=0.03ohm (CLOSED LOOP) (PASS)
Any Point (1,2,3,4,5,6) and 7 (Various place on the test strip) = OPEN LOOP (PASS)
1 & 2 = OPEN LOOP (FAIL!) NOT GETTING 350 Ohms
This seems to be unusual problem to have. I have personally tripled checked it. I have asked my friends to check it. Does anyone have an idea what I am doing wrong here.Thanks
I suggest you provide a link to the spec sheets for the device.
I thought it was an April Fools joke as what he says should be impossible.
I wish it was an April Fools joke. But seriously, I feel like I am defying physics here. The strain gauge I am using is CEA-13-125UN-350. I have attached the specs here. But, I am sure its nothing to do with the strain gauge itself. But, then again I feel there is absolutely nothing wrong with the setup.http://www.vishaypg.com/docs/11224/125un.pdf
Do you have the specs for the assembly shown in the photograph? The assembly in the photograph is more than "basic strain gauge".
yes attached along with the previous post.
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
