Trying to install software on a new PC to run Python code I wrote in 2021
  • Thread starter Thread starter Hornbein
    Python
The user is attempting to run Python code from 2021 on a new Windows 11 PC but is facing issues with Anaconda and Spyder, specifically with Spyder failing to connect to the kernel. Despite downloading and reinstalling both Spyder and Python, attempts to execute the code result in crashes or error messages. Suggestions include running Python from the command line to capture error messages and checking environment variables, as the previous setup may differ from the current one. Ultimately, the user has decided that troubleshooting the software is not worth the effort, opting for alternative methods to illustrate their book. The discussion highlights common installation and execution challenges with Python on a new system.
Hornbein
TL;DR
Trying to install software to run Python code I wrote in 2021.
I have some Python code I wrote and ran in 2021. I'm trying to run it again. I have a computer I bought in 2024 running Windows 11.
I used to run under Anaconda. I downloaded that. Attempts to run Spyder, the Python IDE, failed. It wouldn't execute.
So I downloaded Spyder and Python. I was able run Spyder and see my code. But Spyder failed to "connect to the kernel", going into an infinite loop. An Internet search came up with all sorts of different solutions, from rebooting the computer to resetting variables in Anaconda. I tried a number of installs and uninstalls, which incurred some ominous error messages. In the end I was no worse off but Spyder still can't connect to the kernel and execute code. I tried starting Spyder in debug mode : it crashes immediately.
I attempted to execute Python directly from a file. One of those black shell windows would come up for an instant then disappear.
I'm able to start Python from a command line prompt. I don't know how to use it this way. Naturally it doesn't know where any of the files I'm trying to import are.
Any suggestions?
Technology news on Phys.org
Hornbein said:
TL;DR Summary: Trying to install software to run Python code I wrote in 2021.
Open the shell window and go to the directory where the file is and then run the command. The window will stay open and you'll be able to see the error message that it probably threw. My guess is that your previous computer had python installed in a different location than your current one and it's looking in the previous location. After that, odds may be good that you don't have one or more python libraries installed on your current machine that the program needs. Either way, the error message in the window should point you in the right direction.
Likes berkeman, PeterDonis and FactChecker
In addition to what @Borg wrote, make sure that your environment variables are appropriately set. The Python docs at python.org go into some detail about the variables you need to set.
Thanks for you help guys. I've decided getting those programs to run again isn't worth it. There are better ways to illustrate my book.
Learn If you want to write code for Python Machine learning, AI Statistics/data analysis Scientific research Web application servers Some microcontrollers JavaScript/Node JS/TypeScript Web sites Web application servers C# Games (Unity) Consumer applications (Windows) Business applications C++ Games (Unreal Engine) Operating systems, device drivers Microcontrollers/embedded systems Consumer applications (Linux) Some more tips: Do not learn C++ (or any other dialect of C) as a...
