Trying to prove a trig identity
In summary, in order to find the value of cot^2x, you need to convert the cot and tan functions to cos and sin, respectively. Then, you can write the numerator and denominator as fractions with a common denominator and simplify from there.
james_stewart
cos^2x-cotx
--------------- = cot^2x
sin^2x-tanx
every solution I get gives me a zero, not cot^2
Welcome to PF!
Hi james_stewart! Welcome to PF! :smile:
(try using the X2 tag just above the Reply box :wink:)
james_stewart said:
cos^2x-cotx
sin^2x-tanx
Either write cot= cos/sin, tan = sin/cos,
or just multiply both sides by sin2x-tanx :wink:
i did and I'm not getting the proper results.
when i convert cot and tan to cos/sin and sin/cos i get
cos^2-cos^2
sin^2-sin^2
(please use the X2 tag just above the Reply box)
cos^2-cos^2
sin^2-sin^2
No, you should get cos2 - cos/sin on the top …
i did
and on the bottom i get sin2-sin/cos
james_stewart said:
i did
ok, now put sin2-sin/cos as one fraction (ie with everything over the same denominator), and the same for cos2-cos/sin
That's how i did it. but where do i get cot2 from this?
cos2 - cos/sin
sin2 - sin/cos
erm :redface: … put sin2 - sin/cos as one fraction (ie with everything over the same denominator), and the same for cos2 - cos/sin
cos2 - cos/sin
sin2 - sin/cos
You can write numerator as
[cos2xsinx -cosx]/sinx. Then take cos(x) common.
Repeat the same thing for denominator and simplify.
FAQ: Trying to prove a trig identity
What is a trig identity?
A trig identity is an equation involving trigonometric functions that is always true for all values of the variables. It is used to simplify expressions and solve problems in trigonometry.
How do I prove a trig identity?
To prove a trig identity, you need to manipulate and rearrange the given equation using algebraic and trigonometric identities until both sides of the equation are equivalent.
What are some common trig identities?
Some common trig identities include the Pythagorean identities, sum and difference identities, double angle identities, and half angle identities.
Can I use a calculator to prove a trig identity?
No, calculators cannot be used to prove trig identities. You need to use algebraic and trigonometric manipulation to prove the identity.
Why is proving trig identities important?
Proving trig identities is important because it helps to verify the accuracy of equations and expressions, and allows for the simplification of complex problems in trigonometry.
