MHB Trying to reverse structure a calculation to arrive at original variable
To reverse-calculate the original variable A from the known value B, the equation B = (A x 0.0175) + A can be simplified to 1.0175A = B. By isolating A, dividing both sides by 1.0175 yields A = B / 1.0175. This method allows for the determination of A when B is known and the multiplier of 0.0175 is constant. The calculation effectively demonstrates how to derive A from B using basic algebraic manipulation.
lsargent
Trying to reverse-calculate an equation to achieve one of the original variables when not present.
1) You have a number... A (which is always a positive number)
2) A is multiplied by 1.75%
3) This result is then added to A, and the resulting sum being B, i.e. (A x 0.0175) + A = B
In my scenario, the 0.0175 multiplier is known and is constant. Also, value B is known. I'm struggling to reverse structure this equation to arrive at A.
Any help/insight would be greatly appreciated.
Mathematics news on Phys.org
What you have after combining like terms is:
$$1.0175A=B$$
And so dividing both sides by 1.0175, you obtain:
$$A=\frac{B}{1.0175}=\frac{400}{407}B$$
Thank you!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
