Tube Furnace Fabrication: Any Tips or Recommendations?
  • Thread starter Thread starter KYPOWERLIFTER
    Tube
The discussion focuses on fabricating a laboratory tube furnace capable of reaching temperatures of 1300°C or higher. Key components being considered include Mullite tubes, Kanthal A-1 wire, Kaowool insulation, and a stove pipe for the outer structure. The user seeks recommendations for better quality materials and advice on purchasing a thermocouple and thermometer, as well as designing a power control circuit. They mention a potential setup involving a dimmer switch and a bulb indicator for power management. Overall, the project is estimated to cost around $500, and the user plans to share a detailed guide once completed.
KYPOWERLIFTER
Hi All:
I plan on producing a laboratory tube furnace capable of = to or > 1300 C. Does anyone have any experience working with materials designed for these temps?
I have been pricing Mullite tubes: 500 mm L; ~34 ID; ~40mm OD, 18 G Kanthal A-1 wire (to be wrapped around the tube), Kaowool insulation blanket, and a piece of 'stove pipe' to be the outer tube.
Right now I have two questions:
1) Any suggestions as to the above components? By that I mean suggestions, as to better (in terms of quality and ability to take temperature), grades/types?
2) I need to purchase a thermocouple and thermometer. Recommendations? I also need to design a circuit to adjust power to the wire. What would you guys do and how would you arrange it? I was thinking some sort of dimmer switch (have to handle 2000W power @ 230V) parallel with a bulb as indicator?
Bear with me... When I get it going I'll make a how-to thread with pictures.
Thanks in advance
Update:
I have located two Mullite tubes; one @ 83.00 and one @ 86.00
Kanthal A-1 Wire @ 15.00-20.00
ITC 100 HT ceramic paste @ 38.00
Kaowool 1" 2600F 2 ft2 @ 13.50
Variac (for temp control) ebay searching ~100.00
Stove pipe... 10.00-15.00
Thermocouple and thermometer with the TP 04 thermocouple 89.99 http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=260359668034&ssPageName=ADME:X:RTQ:CA:1123
Quartz glass test tube (with ground glass joint) for use inside furnace... ~100.00
I need to find a glassblower, I assume.
Suggestions/Thoughts? This is looking like a 500.00 project...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
