I Two axis motion for any vehicle
The discussion explores the types of motion in various vehicles, highlighting that aircraft exhibit yaw, pitch, roll, and forward velocity, while locomotives primarily have forward velocity. Cars and boats also experience yaw and forward velocity, but they can exhibit roll and pitch during maneuvers like turning and acceleration. The conversation emphasizes that all vehicles can engage in two-axis motion combinations, particularly in aerobatic planes during maneuvers like snap rolls and tumbles. Examples from aerobatic planes, such as the Citabria and Pitts Special, illustrate how these vehicles can demonstrate complex motion involving yaw, roll, and pitch. Ultimately, the discussion underscores that while vehicles may seem limited in motion types, they can perform a variety of complex movements under specific conditions.
Anand Sivaram
This question I have been thinking for some time.
1. For an Aircraft we have 4 types of motion. Yaw, Pitch, Roll and Forward Velocity.
2. For a Locomotive, we can say there are only Forward Velocity. No other axis of motion.
3. For a Car, we have the Forward Velocity and Yaw motion (steering control). For a boat also it would be similar.
Now, the question is do we have any vehicle which could do Two axis motion like (Yaw, Pitch), (Yaw, Roll), (Roll Pitch)
Actually, cars and boats have all three rotational motions maybe not as noticeable. Car roll in turns and pitch during acceleration and braking. Boats especially sailboats roll and pitch depending on the seaway.
You refer to yawing as related to steering but planes can fly in a direction they are not pointed. Car yaw while skidding.
Likes Anand Sivaram and Lnewqban
All those axes and directions are imaginary and pre-made conventions.
Please, see:
https://en.m.wikipedia.org/wiki/Degrees_of_freedom_(mechanics)
Like any other body subjected to external forces, a vehicle moves and rotates in one instaneous unique way, which we like to divide into axes components.
A vehicle lacking sprung suspension and moving on a perfectly flat surface, like a frozen lake, could only have freedom to yaw.
Likes Anand Sivaram
When an airplane (hopefully an aerobatic plane) does a snap roll or spin, it is doing these kind of combinations. At the start of the spin, the nose of the aircraft drops down and to the side with a definite yaw component. But once fully developed, the axis of rotation is primarily up and to the rear - so it is a yaw/roll combination.
Spin demonstration (video).
I looked at several snap roll videos, looking for one where the rotation axis is clearly not just a roll. As it turns out, the Citabria, the plane that I practiced in, demonstrates this better than the others. It seems to hold the yaw component for the the full duration of the snap roll instead of spending a lot of time transitioning into and out of a regular roll.
Citabria snap rollThis next one shows a 10-minute "aerobatic workout" with the Citabria - there are no snap rolls.
It shows simple "clearing turns" (used as a safety check), some "ballistic rolls", and some maneuvers that start out as pitch changes. Notice that even with the clearing turns, the plane rolls into the turn - so there is both a yaw and roll component even with that simple maneuver. It's actually difficult to do a pure roll in the Citabria.
Citabria Aerobatic Workout
Finally, I have never "tumbled" a plane, but some aerobatic planes are rated for them.
Entry to this maneuver is most often with a vertical climb - allowing the plane to loose air speed without stalling. As the plane nears zero vertical velocity, some combination of abrupt control inputs are applied (rudder, pitch, and/or aileron) - but typically with a plan to avoid a tail slide. One plane that's rated for this is the Pitts Special - the closest thing to a bumble bee in human transportation.
Pitts Special Tumble
Another Pitts Special tumble - this time from the spectators view.
Ground view of Pitts Special tumble.
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
