Two blocks attached by a string(dynamic)
  • Thread starter Thread starter MikeMai
    Blocks Two blocks
The problem involves two blocks connected by a cord, with a force applied to one block on a horizontal surface. The user attempts to find the tension in the rope using Newton's second law, accounting for friction. They derive two equations based on the net forces acting on each block, incorporating the coefficient of friction. After substituting and solving the equations, they calculate the tension to be approximately 35N. The solution is confirmed as correct by another forum member.
MikeMai
1. Homework Statement
Two blocks (m1=4.0kg, m2=7.5kg) are attached by a light cord pulled along a horizontal surface by a force of 53N as shown in the diagram. If the coefficient of friction between the blocks and the surface is 0.30, what is the tension in the rope between the two blocks.
M2 -------- M1 ------->Force applied
2. Homework Equations
Fnet= Ma
3. The Attempt at a Solution
I used the Fnet=ma, on m1 i got Fapplied - T - Ff = ma
But i don't know how to find the acceleration. And i know there's two different frictions because of two different mass. So i don't know how to join them together and find Tension.
ps: I just joined this forum, What should i do if i have a a lot of questions or simply want someone to check over my assignment for me before I hand them in? (got like 20-30questions). I don't want to violate the rule so I am just wondering if there's a specific section to post or something.
What about M2?
Apply Newton2 to M2 and then you'll have 2 equations to work with.
If you have other questions you want to post, then create a new thread for each one.
Hmm, ok so now i got this.
m1:
Fnet=m1a
Fapplied-T-Ff=m1a
m2:
Fnet=m2a
T-Ff=m2a
a=T-Ff/m2
plug a into m1's equation
Fapplied-T-Ff=m1(T0Ff/m2)
53-T-(0.30x4.0x9.8)=4.0(T-0.30x7.5x9.8/7.5)
53=1.53T
T=34.565N = 35N
If someone can check if i did the calculation right, it would be greatly appreciated.
Thank you.
Yes, this is correct :)
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
