Two Blocks Sliding: Find Accel & Tension
Two blocks weighing 3.6 N and 7.5 N slide down a 30° incline, connected by a massless string, with different coefficients of kinetic friction (0.10 for the lighter block and 0.20 for the heavier block). The discussion involves setting up free body diagrams and equations for both blocks to find the acceleration and tension in the string. The user attempts to equate forces but encounters errors in their calculations, particularly in the equations for tension and acceleration. Clarifications are requested regarding the calculations and the correct setup of the equations. The expected acceleration is noted to be 3.5 m/s², indicating a need for accurate application of the physics principles involved.
seraphimhouse
Two blocks, of weights 3.6 N and 7.5 N, are connected by a massless string and slide down a 30° inclined plane. The coefficient of kinetic friction between the lighter block and the plane is 0.10; that between the heavier block and the plane is 0.20. Assuming that the lighter block leads, find (a) the magnitude of the acceleration of the blocks and (b) the tension in the string.
Fnet = ma
Doing the free body diagram for the heavy weight,
x-axis: Fn(Heavy) - Fg(heavy)sin(theta) = 0 so, Fn(heavy) = Fg(heavy)sin(theta)
y-axis: Fk(heavy) - Ft - Fg(heavy)cos(theta) = -m(heavy)a
For the light weight i got,
x-axis: Fn(light) - Fg(light)sin(theta) = 0 so, Fn(light) = Fg(light)sin(theta)
y-axos: Ft + Fk(light) - Fg(light)cos(theta) = -m(light)a
I equated each block equation to equal to the Ft to get:
M(heavy)a + fk(heavy) - Fg(hanging)cos(theta) = Fg(light)cos(theta) - fk(light) - m(light)a
I set it equal to acceleration but I get the wrong answer.
I also got the mass of each weight by dividing it by g (9.8 m/s^2) Can this be my mistake in the equation?
Your last equation is wrong.
The acceleration of the heavy block is given as
[ Fk(heavy) - Ft - Fg(hang)cos(theta)]/M = -a
Similarly write down the acceleration for light block.
I setted them both equal to the tension and solved for a.
Will you show the calculations, please?
The tension force from the heavy block and the light block.
a = [Fg(light)cos(theta) - Uk(light)Fn(light) - Uk(heavy)Fn(Heavy) + Fg(heavy)cos(theta)] / (m(hang) + m(light)
The answer in the back should be 3.5 m/s^2
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
