Two Dimensional Motion (Seemingly Simple)
An object starts from rest and accelerates in the +x direction, covering 13.0 m between t=1.00 s and t=2.00 s. The correct acceleration is determined to be approximately 8.67 m/s², which can be derived using the displacement formula that accounts for the distance traveled in both time intervals. The initial velocity gained during the first second is crucial for accurately calculating the acceleration. A simpler approach involves using the difference in displacements over the two seconds to yield the correct result. The discussion emphasizes the importance of considering initial conditions and simplifying calculations for exam scenarios.
learnitall
An object starts from rest at time t=0.00 s and moves in the +x direction with constant acceleration. The object travels 13.0 m from time t=1.00s to time t=2.00 s. What is the acceleration of the object?
a) 5.20 m/s^2
b) 10.4 m/s^2
c) 8.67 m/s^2
d) 6.93 m/s^2
e) 12.1 m/s^2
The correct answer is c)
1. v = v0 + at
2. x= x0 + v0t + 1/2 at
3 v2= v02 + 2a(Δx)
4 Δx= 1/2 (v + v0)t
5. vav-x = (x2 - x1)/(t2-t1)
The problem says that the object starts from rest and assuming my system starts at zero i can use equation 2 to get:
13 m = 0 + 0 + 1/2 a (2)^2
which gives me:
a = 6.5 m/s^2
my next attempt was using the fact that the object traveled more than 13 m because we must take into account the distance traveled in the first second ( from t=0.00 s to t=1.00 s)
To solve for this distance which I called 'd' I tried using equation 2 3 and 4 by substituting 'x' for '13 + d'. Eventually I reach a point where i have to use quadratic formula to solve for 'd' and substitute it back into one of my chosen equations. It gets really complicated and I can't seem to find a nice answer for 'a'. Can anyone tell me what's a good way to solve for 'a'? My way seems too difficult to solve in 5 min (this was a question on an old exam). How do you get 8.67 m/s^2 for 'a'?!
a) 5.20 m/s^2
b) 10.4 m/s^2
c) 8.67 m/s^2
d) 6.93 m/s^2
e) 12.1 m/s^2
1. v = v0 + at
3 v2= v02 + 2a(Δx)
4 Δx= 1/2 (v + v0)t
which gives me:
a = 6.5 m/s^2
Well you know that can't be right because the object is going to have some initial velocity when it begins the 13m portion of its trip, and the time taken to cover just that portion is not 2 seconds (what is it?).
More importantly you need to take into account the speed it gains during the first part of its trip! You really don't care how FAR it traveled in that first second since how far it traveled before doesn't matter to the only portion of the trajectory that is of interest: the final 13 meters.
As I say, the initial distance doesn't matter; The speed vo when it begins the final 13m matters. Write an expression for the just the final part of the journey supposing that you know vo, Δs, and Δt. What's an expression for vo?
Sorry for the late response. I had classes all day and got caught up with other hw.
So I thought about what you said but instead of considering velocities I set up a simpler equation (after all this was an exam so there HAD to be easier way).
I considered displacement:
x(2)-x(1) = 13 m
1. 1/2 (a) (2 s)^2 - 1/2 (a) (1 s)^2 = 13 m
2. 2a - 1/2 a = 13
3. 3/2 a = 13
4. 3a = 26 m/s^2
5. a= 8.66 m/s^2
Likes Yazeedzaid27
Yes, that works too. Quite elegant, in fact. :approve:
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
