Two masses accelerate towards each other
  • Thread starter Thread starter Janek
    Kinematics
To solve the problem of two masses accelerating towards each other, it's essential to start with a clear diagram illustrating their positions. Simply applying F=ma is insufficient; a deeper understanding of the dynamics involved is required. The discussion emphasizes the need to derive an ordinary differential equation (ODE) to approach the solution effectively. Participants are encouraged to demonstrate their initial understanding and outline their problem-solving strategy. Following the forum's homework guidelines is crucial for receiving assistance.
Janek
Hey, I have problem which I have no idea how to solve:
https://ibb.co/5n8JX6m
As you can see: There are 2 equal masses m connected by a massless string with length 2l. Now a constant force F attacks at the center of the string (at P) and pushes the string upwards so that the masses accelerate in x direction towards each other. Find a formula for the acceleration a depending on the time. Thank you for hints and solutions :)
F=ma
Likes malawi_glenn
Start with a diagram of the general position, not the initial position.
But I see no way to get a solution in closed form. Try to get an ODE at least.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
