Two masses colliding relativistically
  • Thread starter Thread starter TristanRE
    Two masses
In a relativistic collision scenario, a mass m moving at 4c/5 collides with another mass m at rest, resulting in a photon with energy E and a mass M. The conservation of momentum and energy equations are applied to determine M and the maximum energy E. Initial calculations yielded M = (m^2 - 10/3mE)^(1/2) and Emax = 3m/10, but further adjustments led to M = (m^2 - 16/3mE)^(1/2) and Emax = 3m/16. The discussion emphasizes the importance of correctly accounting for all momentum components, including the photon and the initially stationary mass. The final expressions for M and Emax are critical for understanding the limits of energy in this relativistic collision.
TristanRE
A mass m moving at speed 4c/5 collides with another mass m at rest. The collision produces a photon with energy E traveling perpendicular to the original direction, and a mass M traveling in another direction. In terms of E and m, what is M? What is the largest value of E (in terms of m) for which this setup is possible?
p=Ymv
E=Ymc^2
(E^2-P^2c^2)_before = (E^2-P^2c^2)_after
I tried using momentum only, and I get the calculation of p_x=4/3mc, p_y=-E/c (I used four momenta) so now this doesn't give me much to go on alone since I'm looking for M first. I tried using equation 3 but it becomes so convoluted I'm not sure how that could help me with the answer at all.
Any suggestions?
OK. These are the x and y components of the momentum of the particle of mass M.
Any suggestions?
Try conservation of energy. For the particle of mass M, use the relativistic expression for energy in terms of mass and momentum. That way, you can use your results for px and py.
I'm not sure this is what you meant, but I ended up doing the following.
P1 = incoming mass 4 momentum = (E1),p1,0,0)
P2 = created particle = (E2,p1,-E,0)
P3 = photon = (E,0,E,0)
I then equate: P2=P1 - P3
I squared it and rearranged, and plugged in for E1 = 5/3m, which yielded M = (m2-10/3mE)1/2
Then for the second part it seems easy (assuming I'm right up to this point). I just solved for how large E can be without the the radical being negative: Emax=3m/10
How does this look? I found an example comparable to this in my textbook, thought its not exactly the same, I think this is right.
What about the 4-momentum of the particle that was initially at rest?
It completely slipped my mind! Thank you.
I redid did it the same way except replacing P1 with PInitial=(8/3m,,p1,0,0)
Thereby obtaining M = (m2-16/3mE)1/2,
and Emax = 3m/16.
OK.
and Emax = 3m/16.
I'm getting the 16/3 in a different place: ##M = \sqrt{\frac{16}{3}\left(m^2-mE\right)}##.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
