Two objects attached with a spring
  • Thread starter giokrutoi
  • Tags
    Spring
In summary, the conversation discusses the problem of finding the maximal acceleration that can be reached by the second object on a frictionless surface. The objects involved in the problem have masses of 0.9 kg and 1.6 kg, respectively, and are held by a person while a spring is shrunk to a distance of 10 cm. The first object is then released, and when it reaches equilibrium, the second object is released. The relevant equations and attempt at a solution are also discussed, with emphasis on finding the velocity of the center of mass and considering the relative velocities of the masses in order to calculate the acceleration of the second object.
  • #71
jbriggs444 said:
I say that it is not possible for 10 cm to be the maximal extension following release of m2. I do not see ehild making any contrary claim.
Edit: In any case, one should judge the truth of the matter by the strength of the arguments offered, not based on trust. If you can follow the arguments and see that the results follow, all is well. .
I think that your argument is more convincing
  • #72
I dislike playing he said she said. But...
giokrutoi said:
maximal compression may be 10 centimeters and if that's true force should be 10 centimeter multiplied by k and acceleration of second mass should be this magnitude divided by m2
and yes I mean right when I write write
ehild said:
Yes, but you need to calculate the compression in meters, and that should be multiplied by k=20 N/m.
That's ehild agreeing that you have to multiply the maximal compression by k=20 N/m but NOT agreeing that the maximal compression is 10 cm.
Edit: Now with that said, how would one go about calculating the maximal compression following the release of m2? There are at least two general approaches that could work.
One approach would be to try to figure out how the new simple harmonic motion would look following the release of m2. Pick a fixed point (the center of mass?) and try to describe the motion of each piece around that point.
Another approach would be to consider energy. How much kinetic energy is there in the bulk motion of the combined system containing m1, m2 and the spring? How much is in their individual motions relative to the center of mass?
  • #73
Sorry, I made a mistake, the maximum distortion is not 0.1 m when both blocks move. You have to determine it first.
I suggest to follow jbriggs' hint concerning energy. You were about on the right track. But you have to define the notations you use.
After the system has been released, the center of mass moves with constant velocity (as there is no external force any more) and the spring with the attached masses performs simple harmonic motion (it vibrates) with respect to the center of mass. The kinetic energies of these two modes of motion add up. You get the energy of the vibration by subtracting the translational energy from the whole kinetic energy the system has when the second block is released and the spring is relaxed. That kinetic energy is converted to maximum potential energy when the distortion of the spring is maximum. But the kinetic energy of the vibration is not 1/2 m2 x22. What is x2? and the vibration involves both masses.
Likes BvU
  • #74
i was thinking about this problem and i came to conclusion that post 33 makes sense if v2 is maximal
EDIT: If that's wrong than period of second object maybe 2 pi m2/k2 1/2 were k2 is different from k which is given because according to yang's theory when spring's length is decreased (it is decreased because I write origin of spring in the center of mass) then k must go up so if I call Z as length of spring when it is relaxed then if I subtract length from m1 to center of mass I will get length of spring from center of mass to m2 and with help of proportion I will calculate k2 which will be higher that original k
can this help me?
  • #75
  • #76
giokrutoi said:
I have stated that before
Well, the 20 N/m is new to me. May I remind you of post # 2? You are now at over 70 posts and still drag in new things (yang ??) that indicate to me that post #6 still applies.
I am surprised the thread drags on so long; I apparently missed the last notification mail and wondered how much further you were.
You have had guidance from three excellent helpers (plus me :rolleyes:, and a comment from yet another excellent member) -- by the way (post 65), ehild is a she -- and are spending way too much energy on what should be a fairly simple exercise.
Pick up some of the advice (work more systematic, be clear about notation and symbol meaning, slow down a bit :smile:) and try the energy approach as suggested in 72 and 73.
Another suggestion: you do this exercise in a certain context in the curriculum material. Most exercises are constructed to let you practice with the lecture material in the current section, plus some basic general stuff and math. If yang were really needed you would have gotten a hint in the problem statement. Elizabeth's excellent (I don't know russian, but fully trust that 43 == 39 :smile: ) translation hasn't got a single indication.
  • #77
can this help me?
What is v2? what do you mean that it is maximal?
If you take the spring as two strings in series, connected at the centre of mass, you can determine the spring constant of both, and also the vibration frequency. Go ahead. But I do not see how you want to proceed and get the maximum acceleration of block 2.
  • #78
If you take the spring as two strings, connected at the centre of mass, you can determine the spring constant of both, and also the vibration frequency. Go ahead.
in file which i have attached to post 33 there is v2 and I state that it is maximum
but i guess that conclusion( in post 33) is wrong because i didn't take in consideration that all the energy can't be in m2
now period of second mass is 2 pi square root from m2 / k2 k2 is spring constant derived from here
if length of spring is Z then center of mass must be on that spring but it must be closer to the bigger mass so if i call distance from m2 to center of mass D than I have to find D
D is derived from here m1(Z-D)=m2D D=Z/m1+m2 so if k constant from Z is k then for D length it is k(m1+m2)
so period is 2 p square root from m2/k(m1+m2)
is that right
  • #79
is that right
No. Check the parentheses and dimensions. I do not understand the sentence "if k constant from Z is k then for D length it is k(m1+m2)"
  • #80
is k(m1+m2)"
sorry i made mistakes there
here in attached file I wrote correct
  • #81
I can not read your attachment. Type in your work.
  • #82
if spring has length Z and i call D length from m2 to center of mass then m1(Z-D)=m2D
D is m1Z/(m1+m2) now spring constant is untiproportional to length so k1 (new constant) Times D equal k times Z so K1=(m1+m2)k/m1
so period is 2 pi square root from m1m2/k(m1+m2)
EDIT : Is that right
  • #83
The spring constant of which piece is k1?
The period is correct.
  • #84
  • #85
OK, but would not it be more logical to call it k2? And what is the spring constant of the other piece and the period of mass m1?
  • #86
i calculated and it's same
EDIT :Now acceleration is omega squared times maximal strechment so omega squared is m1m2/(m1+m2)k
all I have to do is to calculate maximal strechment is that right?
  • #87
Yes.
  • #88
hey I think I figured out everything
look
we can calculate maximal speed of m1 at the release point from conservation of energy all the potential energy is converted in kinetic of m1
then this v is maximal for m1 thing is that m1's coordinate dependence on time look's so
y=XmaxSINUS OMEGA t were we know omega
t is time Xmax is maximal compression
now if we take derivative from that equation we will get velocity dependence on time
v=VmaxCOSINUS omega t
vmax is maximal velocity of m1 in reference frame of center of mass so we have to subtract velocity of center of mass from v maximal which we defined by conservation of energy
vmax also equals XMAX times omega so we know vmax and omega and we can find Xmax
now acceleration of first mass is omwga squared vmax we know both omega and vmax so we can find acceleration a1
then m1a1=m2a2 a2=m1a1/m2
is that conclusion right
  • #89
  • #90
look
Possibly, it's hard to be sure without seeing your working and answer. Keeping all the given data symbolic, (m1 etc.) what expression do you get for the max acceleration of m2?
By the way, you are only given numeric values for initial compression and the two masses, not the spring constant, right? That leaves you without enough information to get a numeric answer for acceleration.
  • #91
no I have spring constant 20n/m.i forgot to mention it in early posts I said that k is given
  • #92
look
That Vmax is valid in the ground frame of reference. After m2 is released, the whole system translates with the velocity of the center of mass, so both objects move with that velocity + the velocity of their vibration.
You turned to the center of mass frame of reference, where the blocks oscillate , but the maximum speed of oscillation is different from Vmax you got previously. You have to subtract the velocity of the center of mass.
If you got it, you can use that the maximum acceleration is maximum speed multiplied by omega. that you know already.
  • #93
yes that's exactly what I was saying
thanks a lot. For waisting your time on. Helping me
  • #94
Just to check, the max acceleration I got for m2 is ##\frac{kx_1}{\sqrt{m_2(m_1+m_2)}}##
  • #95
It depends what x1 means. It should be the initial compression, 0.1 m.
  • #96
I outline the energy method suggested by jbriggs and me :
ΔL = 0.1 m is the initial compression of the spring.
V1 is the maximum speed of block1 after it was released, but block2 still fixed.
The total energy of the system is 1/2 m1V12=1/2 k (ΔL)2
##V_1 = \sqrt \frac {k}{m_1}\Delta L##
Speed of the CoM ##V_{CoM}= \frac {m_1V_1}{m_1+m_2}##
energy of translation ##E_{tr}=1/2 (m_1+m_2 ) \left( \frac {m_1V_1}{m_1+m_2} \right)^2##.
Let be S the maximum distortion of the spring after both blocks were released.
The spring energy is ##E_s =E-E_{tr}= 1/2 V_1^2 \frac {m_1m_2}{m_1+m_2}= 1/2 k S^2##
##S=V_1\sqrt {\frac {m_1m_2}{k(m_1+m_2)}}## and a2=KS/m2.
  • #97
##S=V_1^2\sqrt {\frac {m_1m_2}{k(m_1+m_2)}}## and a2=KS/m2.
Yes, that looks to be what I did too. No need to get into the SHM details.
  • #98
thanks very much
