Two Observers and the Motion of Protons
  • Thread starter Thread starter tomz
    Motion Protons
When two protons travel parallel at the same velocity, an observer moving with them perceives them as stationary, experiencing only electrical attraction. In contrast, a stationary observer sees the protons in motion, generating magnetic fields that influence each other's trajectories. This discrepancy arises because the observers are in different inertial frames, leading to different interpretations of forces acting on the protons. The confusion stems from the relativistic effects, particularly time intervals, which affect the perceived forces. Understanding these differences is crucial for resolving the apparent contradiction in observations.
tomz
35
hello, this is a question from the book that i got no idea on it
'When two proton are traveling at same velocity parallel to each other, like this (respect to groung)
proton A >>>
proton B >>>
an observer is also travel at the same speed along their path. according to him, two proton are stationary, so the only force is the electrical attraction
Another observer who is stationary will observe two proton moving, both create magnetic field which influence the motion of the other proton
What do you say?
I thought the two observer are both in inertial frame, therefore should applied the same law. but the situation is different to that? i am totally confused.
Can anyone help me? thanks very much
I think it's that the time interval is also different,so the effect of the electric force is defferent.You can calculate it.
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up will act downwards and maximum static friction will act downwards Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
