Two Solenoids on top of each other?
  • Thread starter Thread starter MyAmpsGoTo11
The discussion revolves around calculating the change in magnetic flux through a coil wrapped around a solenoid as the current in the solenoid increases. The solenoid has 121 turns, while the wrapped coil has 4 turns. The participants clarify that the magnetic field should be calculated using the 121 turns for the solenoid, and then the change in flux should be determined using the 4 turns of the wrapped coil. The correct formula involves the permeability of a vacuum, the number of turns, the area, and the change in current over time. Understanding the distinction between the two coils' contributions to the magnetic field is crucial for solving the problem accurately.
MyAmpsGoTo11
A 121-turn solenoid with a length of 27 cm and radius of 0.6 cm carries a current of 1.1 A. A second coil of 4 turns is wrapped tightly about this solenoid so that it can be considered to have the same radius as the solenoid. Find the change in the magnetic flux through the coil when the current in the solenoid increases to 4.2 A in a period of 1.13 s. The permeability of a vacuum is 4 pi × 10-7 T • m/A Answer in units of T • m2.
Magnetic flux = permeability of a vacuum X N2 X A X I / length
Change in magnetic flux = permeability of a vacuum X 1252 X A X 4.2 / length - permeability of a vacuum X 1252 X A X 1.1 / length
I'm confused how many turns this would have. Would it just be 125 turns? I have no idea how to count the inductance of two solenoids together.
If the second coil is attached to the first coil such that it carries current as well, then yes, you would treat it as a 125 coil single solenoid. However, if it doesn't carry current, then it's presence is negligible, since it has negligible mass and volume. Thus you would again use 121 coils.
I believe you would use four turns, as the flux is induced in the four turn coil by the 121 turn coil. You will need to know that:
Change in Flux = Change in Field * Cross sectional Area
Change in field = permeability of a vacuum x N x A x (I/t) / length
**Note that it is N and not N^2 as you have previously specified.
Ah right, misinterpreted the question a bit. First use 121 coils to determine the induced magnetic field, then use 4 coils when finding the change in flux.
Precisely. Good luck on the rest of the question.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
