Two Trains and a Bee: Distance Question
  • Thread starter Thread starter putongren
    distance equation
The discussion revolves around a physics problem involving two trains moving toward each other and a bee flying between them. The equations presented aim to calculate the distance the bee travels before being crushed, with a focus on deriving a general equation for the bee's nth flight. It is clarified that the general equation does not involve summation or series. Additionally, the thread was locked due to a duplicate question, directing users to an existing thread for further discussion. The problem emphasizes understanding distance calculations in relative motion scenarios.
putongren
Two Trains and a Bee.
Consider two trains moving in opposite directions on the same track. The trains start simultaneouslyfrom two towns, Aville and Bville, separated by a distance d. Each train travels
toward each other with constant speed v. A bee is initially located in front of the train in
Aville. As the train departs Aville, the bee travels with speed u>v along the track towards
Bville. When it encounters the second train, it instantaneously reverses direction until it
encounters the first train, then it reverses again, etc. The bee continues flying between the
two trains until it is crushed between the trains impacting each other. The purpose of this
problem is to compute the total distance flown by the bee until it is crushed. Assume that
the bee is faster than the trains.
distance = rate * time
This is a question from the MIT Open courseware website.
(1). d = vt + ut let t = time it takes
d = (u + v)t
t = d / (u + v)
(2). d = vt + ut
d - vt = ut. Substitute t with d / (u + v)
d - v*(d/(u+v)) = u*(d/(u+v))
d - v*(d/(u+v)) = “distance of bee’s first flight"
This is to get the distance of the bee’s first flight. I’m not sure how to get the general equation for the nth flight, which is much harder. Does the general equation involve summation or series?
putongren said:
Homework Statement: Two Trains and a Bee.
Relevant Equations: distance = rate * time
No, it does not.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
