Unable to delete file through vb. Net
  • Thread starter Thread starter Hyperspace2
    Delete File Net
When attempting to delete files and folders using Visual Basic 2008, users may encounter errors indicating that the file cannot be accessed. This issue often stems from insufficient access rights, which can lead to an UnauthorizedAccessException when attempting to delete a file. Additionally, if the file has its read-only attribute set, it may also prevent deletion. To resolve these issues, users should check the file's permissions and attributes to ensure they have the necessary rights to perform deletions.
Hyperspace2
Even if I use correct method or code for deleting files and folders, when debugging I get error saying that it cannot access file and hence cannot delete it. What setting of computer I should inprove to enable the delete feature through visual basic 2008
Technology news on Phys.org
I mean the code as. System.IO.file.delete(path of file) doesn't work nor kill(path of the file) works. I think my pc setting is weird. Someone tell me how to correct it.
I'm going to guess that your VB program doesn't have the correct access rights to delete the file. What exception are you getting? The Delete method throws UnauthorizedAccessException if the caller doesn't have the required permission to delete the file.
It also might be that the file you want to delete has its read-only attribute set.
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
