Unable to understnd the question
  • Thread starter Thread starter archita
The discussion revolves around a triangle with angles A, B, and C in arithmetic progression, leading to confusion about their values. The angles are expressed as 60-d, 60, and 60+d, based on the arithmetic progression formula. The main point of contention is whether the triangle can be classified as isosceles or equilateral, with the consensus that it can only be equilateral if d=0. The participants clarify that the triangle cannot be isosceles since the angles differ unless d is zero. Ultimately, the conclusion is that the triangle is equilateral when d equals zero.
archita
101. If A, B and C are the angles of a triangle and e1A, e1B and e1C are in Arithmetic Progression, then the
triangle is:
(A) Right angled but not isosceles (B) Isosceles but not right angled
(C) Equilateral (D) Right angled isosceles
Thought that e1A e1B e1C are angles tried as
e1A
e1B = e1A +d
e1C =e1A + 2d , wherd = common diff.
hence, sum of 3 int angles of triangle = 180
3(e1A + d) = 180
=> e1A + d = 60 degree
hence e1B=60
then i have no clue...
not able to get what e1B e1A e1C stands for...
First, you are NOT asked to find the angles! You are only asked which of "(A) Right angled but not isosceles (B) Isosceles but not right angled (C) Equilateral (D) Right angled isosceles" the triangle is.
It should be obvious that the angles are 60-d, 60, and 60+ d. Do you see that the triangle cannot be isosceles? It can be equilateral only if d= 0. Is "60, 60, 60" an arithmetic progression? If the triangle is a right triangle, then the largest angle, e1C, must be e1A+ 2d= 60+ d= 90 so d= 30. Now what is e1A?
thnks halls. But answer is given it is an equilateral triangle . One more thing why are you taking angles as 60 -d ,60 60+d, I mean why 60?
You got that E1A=60-d. Then E1B=60 and E1C=60+d. That's why 60. And I think there is more than one correct answer. 30-60-90 looks right angled but not isosceles to me.
Yes, I said "It can be equilateral only if d= 0. Is "60, 60, 60" an arithmetic progression?"
Because you had said, correctly, that
"e1A
e1B = e1A +d
3(e1A + d) = 180
hence e1B=60"
If e1B= 60 and e1B= e1A+ d, then 60= e1A+ d and e1A= 60-d. From that e1C= e1A+ 2d= 60- d+ 2d= 60+ d.
The working out suggests first equating ## \sqrt{i} = x + iy ## and suggests that squaring and equating real and imaginary parts of both sides results in ## \sqrt{i} = \pm (1+i)/ \sqrt{2} ## Squaring both sides results in: $$ i = (x + iy)^2 $$ $$ i = x^2 + 2ixy -y^2 $$ equating real parts gives $$ x^2 - y^2 = 0 $$ $$ (x+y)(x-y) = 0 $$ $$ x = \pm y $$ equating imaginary parts gives: $$ i = 2ixy $$ $$ 2xy = 1 $$ I'm not really sure how to proceed from here.
