Uncertainty Principle.... Intent Behind It?
In summary: That's why you will usually only find correct treatments of the uncertainty principle in advanced books like...Ballentine's book, or textbooks like Feynman's "The Character of Physical Law". Unfortunately, most texts aimed at a general audience start by giving a superficial treatment of the subject, and then later introduce the uncertainty principle.
  • #36
Madi Araly said:
I've been pre-occupied with Heisenberg's uncertainty principle for around four years now, and I've come to fabricate a lot of questions.
The most pressing one, however, is as follows:
To me, the uncertainty principle seems to reference our (relatively) poorly controlled methods to measure a particle's momentum and position rather than being some special quantum phenomenon. Is this how it was intended?
If I measure a coffee mug's position using a crowbar, I change the coffee mug's momentum by measuring it. I do not, however, change its momentum simply by having knowledge of the coffee mug's position. This is how I think of the uncertainty principle, but was it meant this way? If it was, then doesn't that screw up multiple other concepts such as entanglement and electron configuration around nuclei?
Or did Heisenberg believe in some phenomenon that changed one of the particle's traits merely because we observed it?
Heisenberg's uncertainty principle is for subatomic particles/micro level. tea mug may be interpreted by Newtonian Physics. my understanding of the principle is that we can never be sure about anything at all. or for that matter truth can never be known to the human mind. this principle may have philosophical implications
  • #37
That's reading more into it than what it says. Many do it, but IMHO it not particularly constructive.
Thanks
Bill
  • #38
This was an interesting video that gives a good view on the uncertainty issue along with other issues in quantum physics. Don't pay attention to the title, it doesn't reflect on the presentation itself. But it demonstrates a perspective you can possibly take on quantum physics that works around it's inherent issues, including uncertainty, the duality, entanglement and so on.
Funny enough this viewpoint actually complies with old electrical engineering descriptions of the universe.
  • #39
Madi Araly said:
Why is it that humans are so certain of this, though?
You see, you are thinking of position and momentum as two completely separated, isolated entities. But the thing is, they are not - you can describe any given system in terms of position, or in terms of momentum, and you will find that these two descriptions are related via an operation called a Fourier transform. Without going into the mathematical details, the consequence of this relationship is that, if you decrease the uncertainty in position ( i.e. you measure position more precisely ), you will at the same time increase the uncertainty in momentum, and vice versa. You focus on position, the momentum gets smeared out; you focus on momentum, the position gets smeared out. Therefore, there is a lower limit as to how accurately you can determine both simultaneously - that's just precisely the HUP. This is a fundamental fact of nature, and not due to any limitation of our instruments.
Likes bhobba
  • #40
You can know somethings position by a single measurement. To know its momentum you require two measurements. You can never know what happened between the two measurements.
  • #41
phinds said:
Absolutely not. The POINT of the HUP is that it is not at all a measurement problem but rather a fundamental fact of nature.
Wave-particle duality?
  • #42
Is wave-particle duality the reason for this?
  • #43
"Wave particle duality" is has been a deprecated concept for something like 100 years now. Yeah, I know you hear about it in pop-sci but it's a waste of time. Quantum objects are not particles nor are they waves. They are quantum objects and there is no "duality" involved, just the fact that they will exhibit wave characteristics if you specifically measure for that and particle characteristics if you measure for that.
  • #44
From what I've learned so far the reason for existence of HUP is because a "wave packet" fulfills the criteria for not having a well defined position/momentum. Yes this may not be real answer but I find it hard to imagine the physical reality of HUP otherwise.
  • #45
The wave particle duality is one of those ideas introduced in beginning texts and popularizations but was really overthrown when Dirac came up with the transformation theory at the end of 1926:
http://www.lajpe.org/may08/09_Carlos_Madrid.pdf
The reason for the HUP is simply the math of non-commuting operators.
Its sometimes counterproductive looking for explanations other than the math - this is one case IMHO.
Thanks
Bill
Likes weezy
  • #46
Thanks
Bill
Then why do most introductory textbooks explain HUP using the wave-packet picture? I am referring to Arthur Beiser's modern physics where he shows how the uncertainty relations come about from wave-particle picture of quantum objects and how Fourier transforms relate position and momentum. I am also familiar with Griffiths' explanation where he uses standard deviations to derive and commutator relations to arrive at HUP. But gives no explanation why the operators don't commute.
  • #47
(You said "particle" once and "packet" once. Was that intended?)
Intro quantum mechanics almost always starts with Schrodinger's equation in the position basis, because the math required (elementary differential equations, a microskosh of complex analysis) is accessible to a second-year undergrad. The Fourier transform relationship between position and momentum then gets you to position-momentum uncertainty pretty directly. The upsides of this approach are that it's a good start for building an intuition about how QM behaves; you can solve some real and interesting problems that way (the hydrogen atom, for example); and the computational techniques are very important. The downside is that if you don't go further, you may be misled into thinking that this one particular case is the whole story; and if you do go further you have to go back over the same ground using a more sophisticated text, something like Ballentine.
For the specific case of position and momentum, it's easy to calculate the commutator directly, for example here: http://quantummechanics.ucsd.edu/ph130a/130_notes/node109.html
  • #48
You must start somewhere even if its not quite correct.
Unfortunately you see this a bit in physics, especially QM, and its really bad in QFT. You need to unlearn things as you go along. Feynman, for example, worried about it but saw no other way:
http://arxiv.org/abs/quant-ph/0609163
You need to see a 'correct' explanation of the double slit that does not depend on the wave-particle duality:
https://arxiv.org/ftp/quant-ph/papers/0703/0703126.pdf
The above is not understandable by the beginning student, which is why its not done that way.
But to make matters worse even that isn't correct as you get even more advanced:
http://arxiv.org/pdf/1009.2408.pdf
Its insidious - unfortunately.
Thanks
Bill
  • #49
The deep answer is symmetry.
See Chapter 3 Ballentine.
And no it can't be explained simply - the proof is deep and tricky - but the result is - well - beauty incarnate.
Thanks
Bill
  • #50
Nugatory said:
(You said "particle" once and "packet" once. Was that intended?)For the specific case of position and momentum, it's easy to calculate the commutator directly, for example here: http://quantummechanics.ucsd.edu/ph130a/130_notes/node109.html
I'm aware of the calculation for commutator b/w position and momentum. What I'm seeking is the reason for this? Experimentally it's quite evident but why does it have to be fundamental?
  • #51
Thanks
Bill
I will be very grateful if you are able to provide me with a link for this.
  • #52
Sorry - you need to get the textbook:
https://www.amazon.com/dp/9814578584/?tag=pfamazon01-20
It derives the actual operators from which the commutation relations trivially follows.
Thanks
Bill
Likes weezy
  • #53
DrChinese said:
If you measure any fundamental observable very precisely - say position - any non-commuting partner observable moves into a superposition of states (momentum, for example). When you later measure that, you will find that the new outcome (for momentum) is random and uncorrelated to any prior measurement of that observable.
Keep in mind that for all practical purposes, particles do not have simultaneous (well-defined) values for both position and momentum. Experiments on entangled particle pairs demonstrate this very convincingly.
You said, 'When you later measure that, you will find that the new outcome (for momentum) is random and uncorrelated to any prior measurement of that observable.'
Why is this? I get that it is not a matter of us having messed anything up due to the act of measurement. Is it a matter of inconsistent timing? I.e., you measured two things at different times and they MAY have changed between times? Not sure, so I ask.
  • #54
smilodont said:
Why is this?
Its because of the commutation relationship between position and momentum operators:
http://physics.stackexchange.com/questions/10362/how-does-non-commutativity-lead-to-uncertainty
As I mentioned the deep reason they have the form they do is symmetry, but, although very beautiful, its an advanced topic.
Another reason, although not quite as strikingly deep and beautiful, is the connection between commutation and Poisson brackets:
http://bolvan.ph.utexas.edu/~vadim/Classes/2017s/brackets.pdf
Thanks
Bill
Likes DrChinese and Mentz114
  • #55
The first answer was brilliant. Although I have a doubt with the statement that not many operators exist that can transform a Ket to a null vector. Is it really so?
  • #56
Yes its so. It means linear operators with an inverse. If AX = 0 A(-1)AX = 0 ie X = 0.
The usual operators in QM are invertable because they are considered diagonalizable ie of the form A = ∑ yi |xi><xi| Let A' = ∑ 1/yi |xi><xi|. A'A = I.
If the above is goobly gook you need to study linear algebra in bra ket notation:
http://quantum.phys.cmu.edu/CQT/chaps/cqt03.pdf
Thanks
Bill
Likes weezy
  • #57
Thanks
Bill
Thank you for clearing my doubts.
  • #58
You said, 'The reason for the HUP is simply the math of non-commuting operators.' By this, do you mean that the way this math works forces you to be 'uncertain'? If so, this seems like an artifact of the math, rather than a result of correct modelling. Or, to put it another way, if we modeled it some other way, it wouldn't be 'uncertain'? Correct?
  • #59
Yes, but only helpful if that hypothetical other model also produces predictions that match the results of the countless experiments that agree with the model that we're using - and such a thing doesn't seem to be on offer anywhere. We don't use the mathematical structure of quantum mechanics because we revel in perverse and counterintuitive results, we use it because out of all the countless mathematical models out there, it's the one that best describes the universe we live in.
That doesn't mean that you have to like it, of course. Einstein went to his grave convinced that there had to be something better - and didn't live to see the wave of experimental results that have proven that any alternative model would have to retain all the features that he found most distasteful in QM.
Likes weezy
  • #60
Then Einstein was right, if we notice the uncertainty caused by the mathematics. This is a sign of something that is an issue. No insult meant here to anyone.
But, I appreciate the answer. I have gotten vague answers before and this helps. Thanks.
  • #61
The uncertainty is not caused by the mathematics, it is described by the mathematics. The only question is whether that description is accurate, and all the evidence that we have says that it is.
We can speculate about the possibility that there is some other mathematical model that would work as well as QM and doesn't have the uncertainty principle baked into its structure, but:
1) No one has been able to find one.
2) There are many experiments (most of them involving pairs of non-commuting observables other than position and momentum) that appear impossible to explain by any such hypothetical alternative mathematical model.
3) The only reason for thinking that such an alternative model must exist is that you find the current model so distasteful that you can't accept it, that there must be a better answer. Certainly you have every right to feel that way... But there's no reason to think that universe cares about whether we like its rules.
It's worth noting that once you learn the mathematical justification for the uncertainty principle, you'll see that it actually has a deep and subtle beauty of its own. It's way more elegant and compelling than the obsolete hand-waving explanation of how you have to disturb the particle and change its momentum to find its position. So as you learn more of the real story you will find that the uncertainty principle is less distasteful than it seems at first sight.
Likes bhobba
  • #62
:smile::smile::smile::smile::smile::smile::smile:
Nothing is caused by math - only described by it.
Its simply a language that has proven particularly suited to physics and related areas.
Sometimes it can be translated to English and explained that way, but in QM mostly it cant. Unfortunately this is one of that mostly.
Thanks
Bill
  • #63
Nugatory said:
Saying that you have all three components of a particle's angular momentum is equivalent to saying that you have a wave function that is an eigenfunction of ##L_x##, ##L_y##, and ##L_z##. That's like saying that you have a triangle with four sides, or the factors of a prime number, or an odd number that is divisible by 2... There is no such thing.
Except for the particular case where all the components of angular momentum are zero.
Likes weezy
  • #64
This is emphatically not the content of the uncertainty principle. The measurement of of the position of an electron in a particular state |ψ⟩ is the result of a random variable. If we let the standard deviation of that random variable be ∆position(|ψ⟩) and then do the same for the measurement of the momentum we get:
∆position(|ψ⟩)•∆momentum(|ψ⟩) ≥ k > 0 independent of |ψ⟩. That's the H.U.P.
So if the state = wave function |ψ⟩ approximates a delta function at a particular value then ∆position(|ψ⟩) will be small, and thus ∆momentum(|ψ⟩) will be large.
  • #65
Well, I wouldn't go THAT far. I'm pretty sure it has caused several headaches for me over the years. :smile:
Likes Markus Hanke, bhobba and Nugatory
  • #66
doctorshankar said:
My understanding of the principle is that we can never be sure about anything at all. or for that matter truth can never be known to the human mind. this principle may have philosophical implications
A more correct reading would be that infinite accuracy in measurement or prediction is not possible. But people don't have goals like that in ordinary life. The human race wants to build taller buildings and faster computers and the like. There are infinite ways to do these things; Physics simply reduces them from infinity to a finite set.
  • #67
As explained previously it places no restriction on accuracy. And yes it is a general characteristic of QM that you can't predict the outcome of observations.
Thanks
Bill
  • #68
Thanks
Bill
Oh. Not accuracy then.
  • #69
NO! That is not what is going on with the H.U.P. bhobba (post #67) is correct, in fact measurement accuracy is not the issue. Here is a simple concrete example:
Let |0⟩ = the vector [1,0] (Q-computing notation), now measure that with the observable X and you get +1 with probability ½ and -1 with probability ½. The standard deviation of the measurements is 1. Accuracy is not involved. Now we go into a q-optics lab and send horizontally polarized photons into a polarization analyzer set at 45º and observe the exit ports labeled +1 and -1. We will confirm the QM prediction with our measurements/observations being 100% accurate. Random results.
In fact, variance(Zmeasurement|ψ⟩) + variance(Xmeasurement|ψ⟩) = 1 quite analogous to the H.U.P. Notice, if |ψ⟩ is near |0⟩ then variance(Zmeasurement|ψ⟩) is near 0 (small) while variance(Xmeasurement|ψ⟩) is near 1 (large).
  • #70
Right. Accuracy and precision are completely possible, repeatability is not. That's basically what the HUP says. If you set up quantum experiments EXACTLY the same every time, you get different results. That's the difference between the quantum world (the real world we live in) and the classical world which turns out to be only an ideal (although it works really well at the macro level)
Likes Zafa Pi
