Uncertainty versus impossibility of measurement
In summary: Within a higher precision than given by the uncertainty principle, the meaning cannot be unambiguously related to theory, and hence is physically meaningless.In summary, the uncertainty principle states that it is not possible to predict with certainty both the result of a position measurement and a momentum measurement for a particle. However, this does not mean that we cannot measure both quantities at the same time. Theoretical constraints may prevent simultaneous measurement, but the HUP itself does not impose such limitations.
SamRoss
36
TL;DR Summary
Can you really not measure the position and momentum of a particle simultaneously or is it just that there is uncertainty in what you will get?
The uncertainty principle tells us that there is no state that a particle can be in such that we can predict with certainty both what the result of a position measurement will be and what the result of a momentum measurement will be. This statement is not the same as saying we can't measure the position and momentum of a particle at the same time. The latter statement is often repeated. Is it correct?
SamRoss said:
Summary:: Can you really not measure the position and momentum of a particle simultaneously or is it just that there is uncertainty in what you will get?
The HUP says that there is a limit to the precision with which the values for certain pairs of physical quantities of a particle can be predicted from initial conditions. In short, this means that you can very much measure both, but only to some limited precision which is less than if you measured either one of them but not the other.
For instance, to get a high accuracy measurement of position of the particle, you need to interact with it using considerable energy. It might as well have been kicked by a mule; it goes skittering off somewhere, momentum completely unmeasured.
I do not believe your second statement follows from the first. In fact, this is what my whole question is about. The statement "The outcome of the measurement cannot be predicted with certainty" is often taken to be synonymous with the statement "The measurement cannot be made precisely". But the latter does not follow from the former. As an analogy, consider a long-jumper in the Olympic games. The statement "No one can predict with certainty how far the long-jumper will jump" is not the same as "The distance the long-jumper jumped cannot be measured precisely." Now, if a particle is in some eigenstate of momentum, we would be able to predict with certainty the outcome of a measurement of momentum but not the outcome of a position measurement. My question is, can both of these things be measured at the same time even if only one of them has an outcome which we can predict with certainty?
Likes PeroK
More precisely, that there is no state which is an eigenstate of both the position operator and the momentum operator. There cannot be any such state because the two operators do not commute.
Yes, but not for any reason to do with the uncertainty principle. It's more fundamental than that.
What would it mean to measure both position and momentum (or any two different observables) "at the same time"? Different observables correspond to different operators. You can only apply one operator in any given measurement. So you can't measure two different observables "at the same time" because you can't make two different measurements "at the same time". You can only make one.
Likes atyy and SamRoss
No, we cannot. More precisely, if we turn on two apparatuses (say one for measuring the momentum and the other for measuring the position) at the same time, both apparatuses will produce definite outcomes, but we will not be able to predict with certainty those outcomes for neither of them.
A particle cannot be in a momentum eigenstate since a particle's wave function must be normalizable.
The problem with your initial question is that the meaning of ''simultaneous measurement of position and momentum'' is quite fuzzy when the required precisions are high. Within a higher precision than given by the uncertainty principle, the meaning cannot be unambiguously related to theory, and hence is physically meaningless.
Likes vanhees71
The central point you are making is valid. The HUP does not, per se, put any constraints on what you can choose to measure. The theoretical problem with measuring position and momentum simultaneously is the state of the particle after that measurement. There are a number of examples where you can try to outwit the UP in some way - and try to force the simultaneous measurement of incompatible observables. In each case, the actual physical constraints that prevent this may be different. Einstein and Bohr famously debated this for many years. There's also an interesting discussion of it here (section 4.3) and also (in a later section I think) on attempts to measure spin in two directions simultaneously:
https://physics.mq.edu.au/~jcresser/Phys304/Handouts/QuantumPhysicsNotes.pdf
Likes SamRoss
The point is that there is nothing in the theory that stops you trying; and, it's not immediately obvious from the theory what stops you succeeding (in a simultaneous measurement of two incompatible observables).
My point was that the notion of simultaneous measurement at extremely high precision is theoretically ill-defined. Hence though nothing prevents one to try, there is no way to check whether one succeeded!
SamRoss said:
...My question is, can both of these things be measured at the same time even if only one of them has an outcome which we can predict with certainty?
Actually, a variation of this can be performed using spin-entangled pairs of particles.
1. You can measure A's polarization at angle X. A subsequent measurement of A at angle X will confirm the outcome of the first measurement. So will a measurement pf particle B at angle X. You can confirm this arrangement at any spin value for X. Of course, and actual measurement of B at angle X is redundant since they are spin entangled.)
2. Next you measure particle B at some non-commuting angle Y (relative to X). This after measuring particle A at angle X as per 1.
The question is: do you now know particle A's value for spin at angle Y, as well as particle B's value at angle X? Because if you did, you would now "beat the HUP". After all, A and B are entangled so a measurement on one yields information about the other. What do you think?
First, what kind of apparatuses are you thinking of, and how could they both be turned on at the same time for the same particle?
Second, supposing this could be done, what operator would such a measurement realize? As I said in post #4, you can only apply one operator per measurement.
Isn't it also "fuzzy" (as in, not well defined) when the precisions aren't high? How can you measure two different operators simultaneously?
How would you describe "trying" using the math of the theory?
Having measured A’s polarization at angle X and B’s polarization at angle Y, it would seem like we have enough information to predict the outcome of an experiment measuring either A at X or A (same particle) at Y. However, this should not be possible though I’m not well-versed enough to state where exactly the argument breaks down.
The Heisenberg-Robertson uncertainty relation for any position and momentum component in the same direction says that for any (pure or mixed) state fulfills ##\Delta x \Delta p_x \geq \hbar/2##. Here ##\Delta x## and ##\Delta p_x## are defined as the standard devitions of the corresponding probability distributions. This means that it is impossible to prepare a particle in any state such that this product is smaller than ##\hbar/2##. This means the better you determine the particle's position in ##x## direction the less determined is the particle's momentum component in the ##x## direction and vice versa.
It doesn't say anything about, how precisely you can measure ##x## or ##p_x## nor how precisely you can meausure ##x## and ##p_x## "simultaneously". That's a much more complicated question, which needs a lot of careful analysis for any given concrete measurement device that you use to do the one or the other measurement of position and/or momentum.
Often the HUP is errorneously mixed up with the other issue of disturbance of the system by a measurement, which is due to Heisenberg's first paper on the subject, which was immediately criticized by Bohr precisely of this misunderstanding: Again: The HUP as derived in standard textbooks thus says something about the impossibility of state preparation such ##x## and ##p_x## have standard deviations not fulfilling the uncertainty relation, but it doesn't say anything about what's measureable in principle and how much a precise measurement of the one observable disturbs the determination of the other observable.
For a detailed study on the latter question and in which sense Heisenberg's old "micrsoscope agument" can be stated more correctly, see
https://arxiv.org/abs/1306.1565
Likes SamRoss and PeroK
The simple answer is that you don't know the "extra" information because it would defy the HUP.
This was in fact the essence of the famous EPR paper of 1935, written long before entanglement could be tested. EPR thought you could learn (using the described technique for momentum and position) more information than QM (the HUP) would allow. But now we know that the HUP applies here too. Therefore, it is NOT an issue of being unable to measure both simultaneously - because this setup allows that. And it clearly shows that the HUP is a valid limit to what any particle has for non-commuting observables.
Likes SamRoss
1. If I understand your posts correctly, the problem with measuring position and momentum simultaneously does not have to do with the HUP. Instead, simultaneously applying the techniques normally used to measure position with the techniques normally used to measure momentum does not result in knowledge of position and momentum but rather knowledge of a completely new operator. Is that right?
2. This is related to something I've always been curious about - is there any way to look at the equipment in a laboratory and say, "Well, this setup is clearly designed to measure the such-and-such operator"?
3. Further, while the HUP may not say that non-commuting operators cannot be measured simultaneously, is there still a proof of this statement?
So there is a "disturbance" inequality which is separate from the standard HUP?
What I was saying is that you can only apply one operator at a given measurement, and position and momentum are two different operators, so you have to pick one. I'm not sure what it would even mean to simultaneously apply a position measurement technique and a momentum measurement technique, let alone what "completely new operator" such an application would correspond to. IMO, the first thing anyone who claims such a thing can be done should do is to explicitly describe how they would do it.
If you read those notes by JD Cresser that I linked to, there is some excellent analysis of the HUP and the original "old" HUP.
In any case, QT has the HUP and the generalised UP (for any non-commuting operators). I'd focus on those. The concept of measurements "disturbing" a system turns out to be a red herring, IMO.
There is no problem to measure both to macroscopic accuracy. The fuzziness involved is far below the accuracy of the measurements, hence irrelevant. For high precision measurements, this is no longer the case and one needs careful investigations.
In the sense that we can just use classical mechanics as an approximation for this case, yes. But classical mechanics doesn't model measurements with operators.
What I'm asking is, for the quantum case, where we can't use classical mechanics as an approximation, and we are modeling measurements with operators, how would we model "measure position and momentum simultaneously"? Or, in the case of spin, something like "measure spin-z and spin-x simultaneously"? Let alone physically realize such a measurement?
Yes. See the discussion in the references given here and here.
I gave here a very concrete example of a joint position and momentum measurement of quantum particles.
Note that all complex measurements make use of classical mechanics for the auxiliary part of the measurement setting. Generally, only the part sensitive to the quantum degrees of freedom is handles by quantum mechanics. Otherwise it would be impossible to measure anything quantum at all.
Likes SamRoss
From that post:
A. Neumaier said:
Note that we measure both position and momentum, which is not covered by Born's rule.
But it is described by a POVM with an operator for each of the ##w^L## possible signal patterns.
So the observable being measured is neither position nor momentum; it's a POVM which is a different operator from either of those. Certainly it is not a Hermitian operator describing "measure position and momentum simultaneously", since no such Hermitian operator exists (the product of the position and momentum operators is not Hermitian). This POVM can be described in ordinary language as "a measurement of both position and momentum" only because "measurement" is here being used in a different sense than the sense in which it is being used in the OP's question.
There's a discussion of this in the above link (section 6.4.3). The idea is, in the SG experiment, to vary the magnetic field in the ##x## and ##z## directions in such a way that there is measurable deflection in both the ##x## and ##z## directions. Hence, effectively a simultaneous measurement of ##x## and ##z## spin components. But, it never works out. Somehow the precise rules of the interaction between the electron/atom and the magnetic field conspires to prevent a clear deflection in more than one direction.
This is what I meant when I said that the theory doesn't outright forbid this experimentally in some clear way. In each case, it seems to be a different conspiracy of the laws of physics to enforce the UP.
Likes SamRoss
In the example I presented, you can measure both simultaneously* to unlimited precision. It does not change the results - a subsequent measurement of the non-commuting partner observable will NOT yield the expected value (as would be expected if the HUP was false). On the other hand, you can measure the original spin observable all day long and get the same answer each time.
That's pretty good proof.
*Keep in mind this is not to be taken too literally as you are measuring the particles separately.
This is nitpicking; everyone calls this a joint position and momentum measurement.
A position operator cannot be measured in the strict Born's sense since it has a continuous spectrum. Whatever experimentalists do to measure position has a finite (and fuzzy) resolution and hence measures a POVM, not the position in your academic sense. The Born measurements are idealized abstractions, even in the case of spin measurements - as the references in the discussion of the POVM thread linked to show, realistic Stern-Gerlach experiments also need POVMs for their interpretation.
To try to put this and the posts of yours that led up to it in terms that might be easier for the OP to follow:
You can only measure one operator with a single measurement, but the choice of possible operators to measure is much wider than just "position" and "momentum" as those operators are described in introductory QM textbooks. (And pretty much all of the operators described in introductory QM textbooks are highly idealized ones that can never be exactly realized in practice.) In particular, it is possible to choose an operator that gives results that say something like: "the position is within some range x1 to x2, and the momentum is within some range p1 to p2", where different operators of this type will have different widths of the ranges for position and momentum, and the product of the two ranges can be no smaller than a finite limit.
  • #31
I read the section you recommended, 4.3, which had to do with the double-slit experiment and a quantum eraser. It was an interesting discussion about how knowledge of a system results in the loss of interference but I'm not sure how it ties into this discussion. Did I read the wrong part?
The generalised UP doesn't seem to me to provide any new insight into this discussion than the HUP. In fact, many of the posts so far have already implied the GUP by discussing spin operators rather than position and momentum. I agree that disturbing a system is often a red herring when the goal is an understanding of the HUP or GUP but isn't it relevant in a discussion about simultaneous measurements?
  • #32
What precisely is the outstanding question?
  • #33
As far as I'm concerned, my original question has been answered satisfactorily by you and others. The HUP does not tell us that we can't measure the position and momentum at the same time but there are other reasons why we cannot do so. I do not have any outstanding questions at the moment; I was simply responding to your post. In particular, I was a bit confused by the suggestion that I should focus on the generalized uncertainty principle which I thought we already established is not helpful in understanding why position and momentum cannot be measured simultaneously. As vanhees71 suggested and A. Neumaier confirmed, there is a separate disturbance inequality which is more useful here. In any event, I will go back and read the analysis of the HUP vs. the "old" HUP as you suggest. It sounds interesting. Thanks everybody for your help!
  • #34
Have I spoken too soon? Here's a quote from pg. 19 of Cresser's Quantum Physics Notes: "However, the uncertainty relation does not say that we cannot measure the position and the momentum at the same time. We certainly can, but we have to live with the fact that each time we repeat this simultaneous measurement..." So just to be clear, Cresser is wrong here, right? It has been the conclusion of this thread that position and momentum cannot be measured simultaneously albeit for reasons other than the uncertainty principle.
  • #35
It depends on what you mean by "measure position and momentum simultaneously".
It is not possible to apply two different measurement operators in the same measurement. So if by "position" and "momentum" we mean the two different measurement operators that usually are called by those names in QM textbooks, we can't measure them both simultaneously because we can't apply both of them in the same measurement; we have to pick one. (Strictly speaking, what I have just said only applies to operators that do not commute, but this is the case for the QM textbook position and momentum operators, and for spin operators in different directions.)
However, it is possible to find single measurement operators that, when applied in a measurement, give information about both position and momentum. For example, we can find operators of the kind @A. Neumaier has described, which, as I said in post #30, give results that say things like: "the position is within the range x1 to x2, and the momentum is within the range p1 to p2". This is not an exact measurement of either position or momentum, but it gives information about both position and momentum.
Probably the quote in the text you refer to means the second of the two options above.
Likes PeroK and SamRoss
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
