Uncertainty, volume, and measurement
The discussion revolves around calculating the volume and uncertainty of a sphere with a radius of 19.31 ± 0.13. The user calculated the minimum, average, and maximum volumes but found their percentage uncertainty of 4.04% to be incorrect. They were advised that calculus could help in understanding how to derive uncertainty but were reassured that their current method was acceptable. The conversation highlights the importance of understanding significant figures when reporting uncertainty. Overall, the user seeks clarification on their calculations and guidance on using calculus for better accuracy.
mncyapntsi
Find the % uncertainty of the V of a sphere with r = 19.31 plus or minus 0.13...
v=3pi/4r^3
I have done this question and gotten:
Vmin = 4pi/3(19.18)^3=29555.2
V = 4pi/3(19.31)^3=30160.3
Vmax = 4pi/3(19.44)^3=30773.5
Uncertainty: {[30773.5-29555.2]/30160.3}x100=4.04% however this is wrong...
Could someone please help me find out where I went wrong, or tell me if I went the wrong direction? I was told I should apparently be using calculus to solve this, but I have no clue where to even start...
Any help would be much much appreciated!
Have a wonderful day
How is the uncertainty defined?
mncyapntsi said:
Homework Statement:: Find the % uncertainty of the V of a sphere with r = 19.31 plus or minus 0.13...
Does this amount to an absolute uncertainty of 0.13 or 0.26?
You may or may not have received guidance about significant figures in reports of uncertainty. It is almost never appropriate to report uncertainty to more than two significant figures.
Relevant Equations:: v=3pi/4r^3
Have you taken calculus yet? Are you familiar with derivatives? Also, why do you think you are wrong?
Note the "plus or minus". How does that compare with your answer of 4%?
You can use calculus. It leads to a useful general result about how small fractional errors in a linear dimension translate into fractional errors in two and three dimensions. But for the purpose of this question, your method is fine.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
