Uncovering Contrast in Bright Field Microscopy: Beyond Shadows and Imperfections
  • Thread starter Thread starter superwolf
    Field Microscopy
Contrast in bright field microscopy is primarily generated by the differential absorption of light by various tissue types, with staining enhancing this effect. While shadows, pits, and scratches contribute to contrast, scattering from inhomogeneities also plays a role, albeit to a lesser extent. Techniques such as reducing the numerical aperture of the condenser or employing oblique illumination can improve scattering contrast. The limitations of contrast in bright field microscopy have led to the development of alternative imaging methods like darkfield, phase contrast, and fluorescence. Understanding these contrast mechanisms is crucial for optimizing microscopy techniques.
superwolf
What gives raise to contrast in bright field microscopy, except shadows, pits and scratches?
Well bright field microscopy relies on light passing through the sample on its way to your eye. Different types of tissues would absorb the light differently, and this is what gives the technique its contrast. To enchance the contrast the sample can be stained, which would help absorb more light than by the tissue alone.
Generally, contrast in brightfield imaging is limited to absorption. However, contrast can also occur by scattering off inhomogeneities. The contrast from scattering is generally low but can be increased by decreasing the numerical aperture of the condenser or by using oblique illumination.
The lack of contrast is what drove the development of alternate imaging methods- darkfield, Rheinberg, phase contrast, DIC, polarization, fluorescence, etc.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Assume that this is a case where by sheer coincidence, two sources of coherent single-frequency EM wave pulses with equal duration are both fired in opposing directions, with both carrying the same frequency and amplitude and orientation. These two waves meet head-on while moving in opposing directions, and their phases are precisely offset by 180 degrees so that each trough of one wave meets with the crest of the other. This should be true for both the electric and magnetic components of...
