Undergrad Uncovering the Mystery of Calorie Constants
  • Thread starter Thread starter barryj
    Constants Mystery
The discussion centers on the calculation of calorie constants for carbohydrates, proteins, and fats, which are traditionally known to be 4, 4, and 9 calories per gram, respectively. An experiment using soup, peanut butter, and a protein mix yielded calculated values of 3.65 for carbs, 10.391 for protein, and 5.85 for fat, which deviated significantly from the expected constants. The discrepancy arose when using different calorie values from food labels, leading to confusion about the results. It was noted that using adjusted values from the labels resulted in expected outcomes, highlighting the sensitivity of the calculations to slight changes in input data. The discussion emphasizes the importance of accurate data in mathematical modeling of nutritional values.
barryj
When calculating calories of a food..
It is sort of well known that carbs have 4 cal/gram, protein has 4 cal/gram and fat has 9 cal/gram. I wanted to do an experiment to determine these constants 4,4,and 9
I looked at soup, peanut butter, and a protein mix to get the values from the labels per serving and the data is...
soup carb 13, prot 2, fat 2, calories 80 (78)
p butter carb 8, prot 7, fat 15, calories 190 (195)
mix carb 18, prot 2, fat 4, calories 110 (116)
Note: numbers in ( ) are calculated from the 4,4,9 values. These numbers are reasonably close to what was listed on the label
so I set up a matrix where a= cal/gram for carb, b = cal/gram for prot, and c = cal/gram for fat
The matrix is..
13a + 2b + 2c = 80
8a +7b +15c = 190
18a + 2b + 4c = 110
Solving I got a = 3.65, b = 10.391 really?, and c = 5.85 ?really.
My calculated values are not even close to what I expected, around 4,4,9
Does anybody know why this is?? I am really puzzled.
Mathematics news on Phys.org
The matrix is..
13a + 2b + 2c = 80
8a +7b +15c = 190
18a + 2b + 4c = 110
In your matrix calculation, if you use the numbers you showed in parentheses (78, 195, 116), it comes out exactly as you would expect. This shouldn't be a surprise, as you used the values 4, 4, and 9 for the cal/g for carbs, protein, and fats. The seemingly relatively small change from (80, 190, 110) to (78, 195, 116) makes a fairly significant change in the solution, most notably on the value of your b variable (cal/g for protein).
Geometrically, you are working with three planes in space, and determining the point they have in common. By changing all three equations, even relatively slightly, you are changing the intersection point.
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
