Uncovering the Mystery of Electrolytic Cells: The Truth About Free Energy
  • Thread starter Thread starter imhungry
    Thermo
A discussion revolves around the efficiency of electrolytic cells for hydrogen and oxygen production under varying pressure conditions. A friend demonstrated a setup where the cell operates 30 meters underwater, suggesting that the gas produced could provide work as it rises. However, concerns are raised about the validity of claims that gas production remains unchanged under pressure, as thermodynamic principles indicate that higher pressure should affect reaction equilibrium and voltage requirements. The need for more specific data on the pressures tested is emphasized to clarify these claims. Overall, the conversation highlights the complexities of electrolysis and the potential for misunderstanding in experimental results.
imhungry
A friend has asked a question of me that has me wishing that my days of thermodynamics were not so long in the past. He and some colleagues have been making electrolytic cells for high production of hydrogen and oxygen from water. In demonstrating one to me he posed an experiment that on the surface seems to produce free energy, which we all know is impossible.
They have tested the cell under pressure and found that it's gas production and the amount of electricity used are no different than at normal atmospheric pressure. He proposed the following setup. Place the electrolytic cell 30 meters under the water (or what ever, the depth does not matter). Flip the switch and hydrogen and oxygen are produced , no surprise there. The energy content of the gasses is not the issue. The gasses can also provide work when they rise to the surface. The amount of gas produced and the amount of electricity used depth is the same as produced at the surface so that part of the equation is a wash. The work provided by placing the cell beneath water and harnessing energy from the rising gas is the part that I cannot account for.
What am I missing?
Science news on Phys.org
Hi imhungry, welcome to PF!
With respect to your colleague, I question the claim that gas production was not decreased under higher pressure. Higher pressure should shift the reaction equilibrium and require more voltage, as we know from thermo. Is it possible that decreased gas production or higher required voltage was not detectable within error at the pressure they tried? Was the testing pressure 2 atm or 1000 atm, for example?
Thanks Mapes,
I don't know what pressures he tested at but your response is in line with my first thoughts on the issue. My guess is that his tests were at low (a few atmospheres) levels. I will "pressure" him into giving more details.
I would be curious to know how easy electrolysis becomes if the pressure is just above the vapor pressure.
Been around 40 years since I took basic physics in college and while I remember doing some examples of insulation values / energy conduction, I doubt I could to the math now even if I could find the formulas. I have some some corrugated plastic sheet (think of the plastic signs you see on the side of the road) that is used in bee hives. Also have some used in a green house though a bit different in dimensions than this example but the general approach should still apply. Typically, both...
Problem: You’re an Uber driver with a Tesla Model 3. Today’s low: 30F, high: 65F. You want to reach a USD$ profit target in the least number of hours, but your choices could have added cost. Do you preheat the battery only when you are headed to the charging station (to increase the charging rate by warming the battery — however the battery might not be “warm enough” when your reach the charger and thus slower charging rates), or do you always “navigate to the charger” the entire day (which...
Thread 'Is Callen right in claiming dQ=TdS for all quasi-static processes?'
Hello! I am currently reading the second edition of Callen's Thermodynamics and an Introduction to Thermostatistics, and I have a question regarding Callen's definition of quasi-static. On page 96, Callen says: Another way of characterizing Callen's definition is that a process is quasi-static if it traces out a continuous curve in the system's configuration space. So far it's all well and good. A little later, Callen claims that the identification of $$TdS$$ as the heat transfer is only...
