Undergrad Aerospace Vs Mechanical.
Choosing between an undergraduate degree in Aerospace Engineering and Mechanical Engineering is a significant decision for those aiming to enter the aerospace industry. Many industry professionals hold Mechanical degrees, suggesting that this path can still lead to aerospace careers, especially for those planning to pursue a Master’s in Aerospace Engineering. However, the entrance syllabus for Aerospace graduate programs indicates a specialized focus that may not be fully covered in a Mechanical Engineering curriculum. It is advised to consult with individuals who have experience in both fields to make an informed choice. Ultimately, a dedicated Aerospace program may provide more targeted training for those specifically interested in aerospace.
Which one is most prefered if someone wish to work in Aircraft Indus..
  • Aerospace Engineering Undergrad.
    Votes: 1 100.0%
  • Mechanical Engineering Undergrad.
    Votes: 0 0.0%
  • Total voters
  • Poll closed .
Natassha
Hello All. I am planning for Undergrad and I am interested in having a part of Aerospace Industry and like to work in Boeing, Cessna etc. I have searched this Forum were some posters posed that Mechanical Engineering is more suited than Aerospace in Undergrad,if you are going to do MS in Aerospace Engineeringand Also half of the staff members of industry have Mechanical degree rather than Aerospace . Is that true even today?
For them who have choosed Mechanical Undergrad
Unlike all US/International Aerospace department where only TOEFL & GRE General Test is sufficient for Admission for Graduate Program in Aerospace Engineering both for Mech/Aero Undergrads, here in my country there is an entrance for Graduate Admission in Aerospace. Below I have quoted the brief syllabus of that Entrance test. Do you think syllabus can be completed in Mechanical Engineering Undergrad.
ENGINEERING MATHEMATICS
Linear Algebra: Matrix algebra, systems of linear equations, eigen values and eigen vectors.
Calculus: Functions of single variable, limit, continuity and differentiability, mean value theorems, evaluation of definite and improper integrals, partial derivatives, total derivative, maxima and minima, gradient, divergence and curl, vector identities, directional derivatives, line, surface and volume integrals. Theorems of Stokes, Gauss and Green.
Differential Equations: First order linear and nonlinear equations, higher order linear ODEs with constant coefficients, Cauchy and Euler equations, initial and boundary value problems,Laplace transforms. Partial differential equations and separation of variables methods.
Numerical methods: Numerical solution of linear and nonlinear algebraic equations, integration by trapezoidal and Simpson rule, single and multi-step methods for differential equations.
FLIGHT MECHANICS
Atmosphere: Properties, standard atmosphere. Classification of aircraft.Airplane (fixed wing aircraft) configuration and various parts.
Airplane performance: Pressure altitude; equivalent, calibrated, indicated air speeds; Primary flight instruments: Altimeter, ASI, VSI, Turn-bank indicator. Drag polar; take off and landing; steady climb & descent,-absolute and service ceiling; cruise, cruise climb, endurance or loiter; load factor, turning flight, V-n diagram; Winds: head, tail & cross winds.
Static stability: Angle of attack, sideslip; roll, pitch & yaw controls; longitudinal stick fixed & free stability, horizontal tail position and size; directional stability, vertical tail position and size; dihedral stability. Wing dihedral, sweep & position; hinge moments, stick forces.
Dynamic stability: Euler angles; Equations of motion; aerodynamic forces and moments, stability & control derivatives; decoupling of longitudinal and lat-directional dynamics; longitudinal modes; lateral-directional modes.
SPACE DYNAMICS
Central force motion, determination of trajectory and orbital period in simple cases. Orbit transfer, in-plane and out-of-plane. Elements of rocket motor performance.
AERODYNAMICS
Basic Fluid Mechanics: Incompressible irrotational flow, Helmholtz and Kelvin theorem, singularities and superposition, viscous flows, boundary layer on a flat plate.
Airfoils and wings: Classification of airfoils, aerodynamic characteristics, high lift devices, Kutta Joukowski theorem; lift generation; thin airfoil theory; wing theory; induced drag; qualitative treatment of low aspect ratio wings.
Viscous Flows: Flow separation, introduction to turbulence, transition, structure of a turbulent boundary layer.
Compressible Flows: Dynamics and Thermodynamics of I-D flow, isentropic flow, normal shock, oblique shock, Prandtl-Meyer flow, flow in nozzles and diffusers, inviscid flow in a c-d nozzle, flow in diffusers. subsonic and supersonic airfoils, compressibility effects on lift and drag, critical and drag divergence Mach number, wave drag.
Wind Tunnel Testing: Measurement and visualisation techniques.
STRUCTURES
Stress and Strain: Equations of equilibrium, constitutive law, strain-displacement relationship, compatibility equations, plane stress and strain, Airy’s stress function.
Flight Vehicle Structures: Characteristics of aircraft structures and materials, torsion, bending and flexural shear. Flexural shear flow in thin-walled sections. Buckling. Failure theories. Loads on aircraft.
Structural Dynamics: Free and forced vibration of discrete systems. Damping and resonance. Dynamics of continuous systems.
PROPULSION
Thermodynamics of Aircraft Gas Turbine engines, thrust and thrust augmentation.
Turbomachinery: Axial compressors and turbines, centrifugal pumps and compressors.
Aerothermodynamics of non rotating propulsion components: Intakes, combustor and nozzle. Thermodynamics of ramjets and scramjets. Elements of rocket propulsion.
I think if you are interested purely in aerospace, then you should go with a course in aerospace only. Mechanical engineering is way general for the syllabus of the entrance test you have put up here. I don't think a course in mechanical engineering would train you well specifically for aerospace. However it is best to first consult people who have pursued mechanical, and those who have done aerospace. And later decide which one would be preferable.
For some background, I'm currently a 3rd year physics major with an astro specialization studying in Canada, and as undergraduates are want to do I'm regularly evaluating my career prospects down the road. I also plan on pursuing grad school when I've completed my degree. It might just be my anxiety acting up a little, but with a lot of the government funding drying up for public science research broadly in the US, the 'industry' everyone keeps talking about when questions like this are...
Hello Physics Forums Community, I'm hoping to draw upon the community's collective wisdom regarding a procedural challenge that I believe many independent researchers face. I'm working on a self-contained theoretical framework from a foundational starting point. The work touches upon concepts from general relativity, quantum foundations, and cosmology, attempting to connect them based on a single relational principle. It has now reached a point, where some parameter free values seemingly...
14K
