- #351
ghwellsjr
- 150
I was very careful to say in post #7 and every other time since then when commenting on this topic that no one is measuring the speed of light. All the observer can do is measure that the flashes of light coming from two different co-moving sources travel together at the same speed but he cannot tell what that speed is.BruceW said:But you are saying it is enough if you also assume speed of light to be the same, as measured by any inertial observer?ghwellsjr said:Correct--I never said it was.
Are you sure you disagree with what I actually said?BruceW said:I still disagree with this,
Again, for right now, I'm not talking about the Twin Paradox. Do you still disagree? And if so, you need something more than that the line of reasoning is not obvious. And if you understand the argument, it is not just plausible, it is incontrovertible proof.BruceW said:...for the same reason:
BruceW said:Sure, you can go down a line of reasoning from this which does correctly explain the twin paradox, but such a line of reasoning is not obvious, only plausible.
In the limited scenario which I borrowed from Bondi, I'm assuming the Principle of Relativity and I'm adding the observable assumption that the speed of light is independent of the speed of the source and proving that the outbound Doppler is the inverse of the inbound Doppler when the speeds are the same. That's what we are focusing on right now. Do you have any problem with that conclusion? Even if it is not obvious, do you see it as incontrovertible proof?BruceW said:Yeah, it all seems fine. You were saying the speed of light is independent of the speed of the source.ghwellsjr said:Try not to associate this with the Twin Paradox or any explanation of the Twin Paradox. This is something entirely different involving three inertial observers. Do you understand the situation I have described? Do you agree with everything I said? Are there any questions or doubts?
