MHB Understanding Algebra Division Formulas: SPI, EV, PV, and AC
The discussion clarifies the relationship between the formulas SPI=EV/PV and CPI=EV/AC, showing that they are mathematically equivalent but serve different purposes. Rearranging these formulas allows for the calculation of one variable based on the others, depending on the available data. For instance, SPI can be used to find EV when PV is known, and vice versa. The confusion arises from the perception of having two solutions, but they are simply different interpretations of the same underlying relationships. Understanding these formulas aids in grasping the fundamentals of algebra in project management contexts.
falcios
If you rearrange this formula from SPI=EV/PV to EV=SPI*PV. Why is this formula like this: CPI=EV/AC is AC=EV/CPI
Aren't they basically the same.
Thanks for the help.
Mathematics news on Phys.org
We begin with:
$$CPI=\frac{EV}{AC}$$
Now, multiply both sides by $$\frac{AC}{CPI}$$:
$$CPI\cdot\frac{AC}{CPI}=\frac{EV}{AC}\cdot\frac{AC}{CPI}$$
$$AC\cdot\frac{CPI}{CPI}=\frac{EV}{CPI}\cdot\frac{AC}{AC}$$
$$AC\cdot1=\frac{EV}{CPI}\cdot1$$
$$AC=\frac{EV}{CPI}$$
I'm still lost aren't the two formulas basically the same why is there 2 different solutions?
Is there a simpler way to calculate for someone who is relearning the basics.
Thanks.
karush said:
also $SPI=EV/PV$ to $EV=SPI*PV$
it should be $SPI=EV/PV$ to $EV=SPI/PV$ you divide both sides by $PV$ to isolate $EV$
You want to multiply both sides by $PV$ to isolate $EV$.
Hello! I'm invading another thread. :o
Falcios, you are right. They are mathematically equivalent, as both Mark and Karush have shown you. However, what I think is really the issue here is: why bother with the equivalent versions?
The answer is that each version helps you calculate one quantity in terms of the others. When you write
$$\text{SPI} = \frac{\text{EV}}{\text{PV}}$$
you can find the value of SPI in terms of EV and PV. If, for some reason, you are given SPI and PV, you can find the value of EV in terms of these. Likewise, you can find the value of PV in terms of SPI and EV by doing the calculation
$$\text{PV} = \frac{\text{EV}}{\text{SPI}}.$$
In other words, there are not 2 "solutions", but two ways of interpreting results in light of what data you might have.
Hope this has helped. :D
Cheers!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
