Understanding an RF remote control
The discussion focuses on the transmission of signals from a remote control to a drone, specifically how joystick movements translate into pulse codes that control motor power. It explains that the PPM (pulse period modulation) stream is used for communication between the transmitter and receiver, typically operating at 2.4GHz, with various protocols like One Shot for faster response times. While the PPM signal is standardized, the proprietary nature of the protocols between different manufacturers complicates compatibility, requiring users to match transmitters and receivers from the same brand. Some companies are reverse engineering these protocols to create compatible components at lower prices, but obtaining detailed protocol information from manufacturers remains challenging. Overall, understanding these systems is crucial for effective drone operation and compatibility.
Curt Zerr
Hello!
This question may be a little too specific but if there are any drone enthusiasts out there they might be able to help me out! I'm trying to understand the transmitted signals from a remote control to an air drone. When the user of a remote control, let's say, pushes up on the joystick for thrust, a signal of pulses are transmitted at a specific rate acting as a code. This code of pulses is then received by the receiver and sent through an encoder which then goes to the designated channel on the micro controller of the drone telling it to either send power to the motor or take away power? Am I on the right track here?
Also, are these codes specific to every drone manufacturer or is there a standard for these kind of commands?
Any help would be greatly appreciated!
Thank you
Curt
I think what you are talking about is the PPM stream (pulse period modulation) sent to the receiver/controller and then on to the ESCs which control motor output. What the transmitter does is encode a stream of PPM data on a carrier, typically 2.4GHz. Older RC transmitters used frequencies in the MHz range, but since the last decade 2.4GHz is pretty much across the board now for RC transmitters.
Once the receiver/controller decodes the data stream, it breaks it out into a PPM signal to each servo or ESC for a multi-copter. PPM frequencies range from 50Hz to serveral thousand Hertz. For quite a long time a 50Hz stream was used across the board, but with multi-copters came the need for faster response times. There's various protocols now like One Shot and One Shot 125. These use a higher frequency PPM stream. It's a system wide thing, if you have a receiver/controller than puts out a higher frequency PPM stream you need an ESC (or servo) that can accept it.
Generally the PPM used by servos and ESCs is standardized with the caveat you need compatibility for higher frequencies. All servos and ESCs can use a 50Hz signal, but you have to check servo and ESC specs for anything higher. What's proprietary is the protocol used between the transmitter and receiver. Before the advent of 2.4GHz it was fairly standard, pretty much any transmitter would work with any receiver. With 2.4GHz came digital encoding which is a proprietary thing. For example if you use a Spektrum transmitter, you have to use a Spektrum receiver.
Likes berkeman and Averagesupernova
Thank you so much!
This answered a lot of questions. So I guess the only way to know these control protocols is to talk to the manufacturers of the transmitter/receivers themselves. I imagine this is information that is not easily obtained...
Yes it is not easily obtained. They keep their protocols close. It's actually something that is a major complaint with RC modelers. But, that's the way these makers do it so that's what we get. There are some companies reverse engineering protocols to offer components in a cheaper brand. For example the protocol used by Spektrum is called DSMX. A company by the name of Lemon offers DSMX compatible receivers for a lot less than what Spektrum charges. They work just as well, but to design them Lemon had to reverse engineer the protocol. There's others like that. Another example, Walkera offers a transmitter that runs firmware called Deviation allowing the transmitter to use various protocols designed by other makers. So there's ways around this situation, but generally it's best to buy your transmitter and receivers to go with it under the same brand.
Ok I see. That makes sense. Thanks a lot for all the information!
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
