- #71
Gordon Watson
- 375
JesseM said:Bell locality just says it should be possible to find a set of information about hidden variables λ that's sufficiently complete such that the two sides of the above equation will be equal. It doesn't say the opposite, that you can't find a more restricted λ such that the two sides are unequal--of course you can! For example, λ could be defined in such a way that it contains no information about anything in the past light cone of either measurement, in which case it should be completely irrelevant and P(G|X,a,λ) = P(G|X,a) and so forth. In that case the above inequality may be correct, despite the fact that X is a local realistic theory. Again, Bell is just saying that under local realism it should be possible to define some λ so the two sides of the equation become equal.
It's not a supposition, any physicist will agree that under a local realist theory, as long as enough information about local variables (hidden or otherwise) in the past light cones of G and G' is contained in λ, your equation (3) should be satisfied. If this doesn't make sense to you, perhaps you could address my post #29?
Also, consider the following:
--In a local realist theory, all physical facts--including macro-facts about "events" spread out over a finite swatch of space-time--ultimately reduce to some collection of local physical facts defined at individual points in spacetime (or individual 'bits' if spacetime is not infinitely divisible). See my first few comments in this post from another thread. So, any fact of the matter about the result of a measurement can be reduced to a set of local facts about events associated with the smallest possible units of spacetime. Without loss of generality, then, let G and G' be two possibilities for what happens at some single point in spacetime P.
--In a deterministic local realist theory, if λ represents the complete set of local physical facts that lie in the past light cone of P at some time t prior to P, then this allows us to determine whether G or G' occurs with probability one, so any additional information would not cause us to alter our probability estimate. Thus in this case it should be clear that your equation (3) above is satisfied.
--An intrinsically probabilistic local realist theory is a somewhat more subtle case, but for any probabilistic local realist theory it should be possible to break it up into two parts: a deterministic mathematical rule that gives the most precise possible probability of a given event happening at point P based on information in the past light cone of P (if information outside that past light cone of P was required to get the most precise possible probability estimate, the theory would not be a local one), and a random "seed" number whose value is combined with the probability to determine what event actually happened. This "most precise possible probability" does not represent a subjective probability estimate made by any observer, but is the probability function that nature itself is using, the most accurate possible formulation of the "laws of physics" in a universe with intrinsically probabilistic laws.
For example, if the mathematical rule determines the probability of G is 70% and the probability of G' is 30%, then the random seed number could be a randomly-selected real number on the interval from 0 to 1, with a uniform probability distribution on that interval, so that if the number picked was somewhere between 0 and 0.7 that would mean G occurred, and if it was 0.7 or greater than G' occurred. The value of the random seed number associated with each probabilistic choice (like the choice between G and G') can be taken as truly random, uncorrelated with any other event in the universe, while the precise probability of different events could be generated deterministically from a λ which contained information about all local physical facts at all points in spacetime in the past light cone of P. In this case, it would again be true that your equation (3) above would be satisfied.
Do you think it is possible to imagine a "local realist" theory where one of the above would not be true?
Dear Jesse,
Thank you for this detail. You provide much to study. Maybe some is beyond me.
Certainly there are some distracting generalities --
"It's not a supposition, any physicist will agree that under a local realist theory, as long as enough information about local variables (hidden or otherwise) in the past light cones of G and G' is contained in λ, your equation (3) should be satisfied."
For the moment -- to minimize distractions and focus on Bell's mathematics --
I have shown the realistic locality assumption that reduces (1) to (2). With Einstein and Bell as supporters. [Edit: I also give the assumptions to pass from (2) to (4) and from (2) to (5).]
1. Could you show me the assumption that you use to reduce (2) to (3) please? With some support.
2. With your assumption, would all probabilities be zero or one only?
Again thank you,
Jenni
