- #71
Lynch101
- 85
I don't believe I am making assumptions on my own, though. I am drawing, or trying to draw, conclusions from the different sources I've referenced, as well as from your statements here. Those conclusions may not be accurate, but I'm not yet clear as to why they are, or even if they are.PeterDonis said:What does Bell say it encapsulates in his paper? You should be reading that, not making assumptions on your own.
With regard to what Bell says in his paper, the statement from Bell & Gao above suggests that there is an implicit assumption about screening off which is made explicit in his exchange with Shimony, Horne, and Clauser.
Thinking about the point I'm trying to get at, I'm tending toward greater clarity in my own thinking, which will hopefully translate here. I'll try and set out my thinking in numbered points. If there is an issue somewhere it might be easier to identify and home in on.
I hope my use of the terminology is correct here.
- The preparation of the particles is a function of ##\lambda##.
- ##\lambda## itself is a function of everything in its past light cone.
- Therefore, the preparation of the particles are a function of everything in their own past light cone (including the past light cone of ##\lambda##).
- The measurement settings are not a function of ##\lambda##.
- The measurement settings are a function of everything in their past light cone.
- If we go far enough back into the past, the light cones of the measurement settings and the preparation process (including ##\lambda##) intersect with a common cause.
- This common cause would explain the observed correlations.
- Therefore, either the measurement settings or the preparation process needs to be screened off from this common cause i.e. the chain of causality needs to be interrupted somehow.
- Usually, this is simply assumed i.e. it is the assumption so pervasive that it is difficult to see how we could engage in experimental science without it.
- Isolating the mechanism for choosing the measurement settings from the preparation process doesn't screen either off from the common cause in their past light cone - it means, perhaps, that the common cause event is located further in the past light cones.
- Without some kind of "circuit breaker" event, to interrupt the chain of causality, the assumption of statistical independence appears to be unjustified.
- The free will of the experimenters is invoked to justify the assumption, because "free will" is the only conceptual idea we have that necessitates non-correlation with events in the past light cone.
Hopefully this clarifies my thinking and makes it easier to identify where the breakdown is. I really hope my use of certain terminology is correct here.
