Understanding Chromosomes: How Parental Genes are Activated in Somatic Cells
  • Thread starter Thread starter Dr. Nick
In somatic cells, both maternal and paternal chromosomes are present, but not necessarily both are active at the same time. Typically, both chromosomes can be uncoiled and contribute to protein synthesis, resulting in a mixture of proteins from each parent. This genetic variation explains the concepts of dominant and recessive traits, where a dominant gene can be expressed with just one active chromosome. However, certain conditions can lead to only part of one chromosome being active, such as mutations that inhibit transcription. A specific example is in female mammals, where one of the X chromosomes is inactivated to balance gene expression between the two X chromosomes.
Dr. Nick
Two same chromosomes, each from one parent in our somatic cells.
So how is it chosen which one will be active in one cell ? Here I wonder, are 2 chromosomes, mother’s and father’s, active and “uncoiled” at the same time in the cell, or only one is uncoiled and used as template ? :blushing:
Biology news on Phys.org
From what I've learned it is usually both. You are getting a mixture of both chromosomes, or both kinds of proteins. This means that if the DNA sequence is not exactly the same and leads to a different amino acid sequence then you will have a mixture of the same protein. This is why some genes are recessive and dominant. Usually the dominant gene only requires one chromsome from one parent.
Reasons why only part of one would be active are:
One parent gave you a chromosome that has a portion that is not expressed due to mutations that inhibit transcription such as the inability to perform 'uncoiling.'
Thank you, I’ve asked this because I thought I’ve read in some cytology book that only one chromosome is active in some cells at the time…
That's true for X chromosomes of females in mammals. To compensate for the presence of an additional X chromosome, females shut off expression of one of the X chromosomes.
I've been reading a bunch of articles in this month's Scientific American on Alzheimer's and ran across this article in a web feed that I subscribe to. The SA articles that I've read so far have touched on issues with the blood-brain barrier but this appears to be a novel approach to the problem - fix the exit ramp and the brain clears out the plaques. https://www.sciencealert.com/new-alzheimers-treatment-clears-plaques-from-brains-of-mice-within-hours The original paper: Rapid amyloid-β...
